    Mar 2005
    Is it safe to do bunny hop with a lefty on rigid?
    Yeah I've read somewhere in this forum that lefties are not meant to be ridden with the rigid on. Is that true?
    Reputation: pecka's Avatar
    Quote Originally Posted by Atomant
    I made 2km downhill once w/ locked Lefty. It was ruff ride, but the fork is ok.
    Jan 2005
    no fork is designed to be ridden locked out for anything except for climbs. they are durable and can take a lot of abuse. but it isnt a warranty if you break it. and i have seen quite a few toasted dampers because they are ridden locked out. so try not to, but they can take some abuse. if you want a stiffer fork, just increase your air pressure.
    Feb 2005
    Safe? yes, wise repeatedly? no. You will crack the shims that control the flow of oil in your cartridge, then it will cost you some bucks. As others have said, it's a tough system, and you can definately ride with it locked out, but it is for climbing, or road sections, it is not a ridgid fork conversion unit. Have fun!
  1. Did Shiver Quit?
    By Roaming Oregon in forum Downhill - Freeride
    Last Post: 06-15-2005, 12:32 AM
  2. About these rigid forks...
    By SpinWheelz in forum Singlespeed
    Last Post: 12-05-2004, 05:15 PM
  3. Cannondale Lefty Max+ compared to TALAS :my $.02
    By dawgcatching in forum Shocks and Suspension
    Last Post: 04-13-2004, 10:39 PM
