Results 1 to 5 of 5
    N2B
    N2B is offline
    s works crank on a flash 29er 2010 ?!!??!
    can it be done with a 2011 crank ?! and is the frame with bb30 73mm or 68mm ?!
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    ... Why not ?
    Sworks is BB30
    Flash has 73mm BB shell
    FIRENZE rulez !!
    Just to be exact :
    Flash BB shell is not wider than Epic BB shell, 9 mm minus.
    So you have to use some custom spacers on both sides ... Many items work on a 30 mm spindle.
    Cheaper and lighter are cogs spacers .
    Hope it helps , ciao
    N2B
    N2B is offline
    Quote Originally Posted by eliflap View Post
    Just to be exact :
    Do you have a link to the cog spacers in a EU shop I should use ?!
    FIRENZE rulez !!
    I had a old cheap and heavy x.7 Sram 11-34 9 speeds cassette
    I disassembled it to have plastic spacers ...
    An hardware shop can helps you with some plastic water pipeline or similar
    I have a 30mm inner diameter carbon tube to cut as i need to have a light and goodlooking result.
    Search in your garage , you can find something can work ...
  1. 2010 Cannondale Flash 3 29er
    By J3SSEB in forum 29er Bikes
    Last Post: 05-10-2012, 05:47 AM
  2. Crank Choice for Flash 29er Carbon?
    By jimification in forum Cannondale
    Last Post: 07-23-2011, 07:30 AM
  3. 2010 Cannondale “Flash" 29er
    By HAL 9000 in forum Cannondale
    Last Post: 04-16-2011, 06:52 PM
  4. 2010 Cannondale Flash 3 29er
    By J3SSEB in forum Cannondale
    Last Post: 11-28-2010, 12:35 AM
  5. 2010 Cannondale flash 29er 1 vs 2010 Gary Fisher Paragon
    By cannondalemtb65 in forum 29er Bikes
    Last Post: 10-03-2010, 10:15 AM
