So i picked up this 2010 rz140. I only run a 22/32 bash front setup. I was using a triple frnt deraill but its topswing and this bike needs a bottom swing. Im thinking getting a 2 speed front deraileur.with the smaller cage. My fear is it needs to be mounted lower than triple frnt derail for clearance while running the 22 because the cage is smaller. Am i gonna runninto problems with how the rear derail cable is routed. It seems the cable wants to be routed rite above the pivot cuz that how cable housings are lined up. My fear is thats about where a lowered compact derailler would want to sit. Anyone with an rz running a.compact frt drail out there? If so how are un runnin the cables? Above under?
