Results 1 to 10 of 10
    Jan 2014
    RZ 120 1.5 headset conversion ?s
    Im trying to put a fox float on to a 2013 RZ 120 1. The stock head set is a 1.5 in and the fox floats only come in 1 1/8 or 1.5 tapered. Can some one please point me toward a head set that might make this frame and this fork integrate?
    I would like to make the 1.5 tapered steer tube(not the 1 1/8) compatible if possible?
    I'm pretty new to all this stuff. Any help or maybe direction to a thread where this has been covered would be appreciated.
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    Haha! We have had this one a few times the last few days but no worry!
    Your headset is an SI or system integration which means the bearings sit directly in the frame. You need the kp205 reducer kit that will enable you to put a tapered fork on your frame.
    I live in the states but ordered mine from qwerty cycles who are based in the uk. Cannondaleexperts.com sell them but I believe they are still out of stock.
    See here: http://qwertycycles.co.uk/products/c...5headset-kp205
    Jan 2014
    Thank you!!! I figured it had to be covered somewhere I guess I just hadn't hit the right key words yet or something.
    Redcoat
    Aug 2013
    No it's a pain in the arse to find. I had same issue as well mate.
    Redcoat
    Aug 2013
    Also as you are new to all this stuff, here's the specs on your mighty machine. It may help in the future if you have further questions.
    Jan 2014
    yep.... that's exactly what I have been using to get my specs. Im going to drop a couple fox floats on it switch to xt brakes and SUNringle black flag wheel set and it should be ready to go.
    I'm not really new to mt biking I just haven't been into it in about 12 years so the technology has long surpassed me.
    Redcoat
    Aug 2013
    Nice mate sounds like you have a great plan for it. Be sure to get some pics up for us to have a gander at.
    Reputation: jetboy23's Avatar
    I had ordered mine from R2-bike.com in Germany and got it stateside in a week. I also just got notice that Cannondale Experts has them in stock again as well. They took about 4 days on my last order from them to get to my door in SoCal and are located in Utah. Just in case you're still looking.
    Reputation: kneejerk's Avatar
    Dec 2008
    are you gonna put a 140 or 120 fork as a replacement? I think either will work and if you check the a/c measurement of your current fork the 140 might be the closer match. I think the fox 120 forks are maybe a little shorter than some others axle to crown.
    Redcoat
    Aug 2013
    Quote Originally Posted by kneejerk View Post
    Op should be good with either. Usually it's ok for geometry etc to stay within 20 mm either up or down.
  1. Threaded headset to threadless headset conversion
    By op12389 in forum Bike and Frame discussion
    Last Post: 08-01-2013, 04:20 PM
  2. headset conversion
    By coronax in forum Shocks and Suspension
    Last Post: 07-25-2013, 11:36 PM
  3. Replies: 1
    Last Post: 06-23-2011, 05:02 AM
  4. Anthem X 2011 Headset Conversion
    By Veda in forum Giant
    Last Post: 06-12-2011, 04:39 AM
  5. cannondale headset conversion to standard fork
    By ssphoenix in forum Cannondale
    Last Post: 02-09-2011, 11:07 AM
