Results 1 to 5 of 5
    Is the Rush setup guide right?
    I have searched and did not find an answer. I am just a bit confused, basically because I am still getting used to a full suspension bike and I am having a small problem getting the front to feel the way I want it. ( I am 220,using a black negative spring, 30mm sag ).
    But the real question is about the DLR2 rebound adjustment knob which says “rebound” with of course a “+ “ and “-“ sign. To me looking at the knob you would turn the knob “+” for more rebound or “-“ for less rebound.
    The Rush set-up guide in reference to adjusting rebound states
    “Turn in “+” direction for more dampening and slower rebound speed”
    “Turn out “-“ direction for less dampening and faster rebound speed”
    So is the setup guide right and I am just reading too much into it?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    The best way to find out is also the most fun: head out to your favorite trail and play with the knob, you'll figure it out fast enough!
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    + means more damping (ie slower rebound).
    This should be pretty obvious by twiddling and seeing the effect.
    Mar 2006
    GlenH is right, + means more damping = less rebound or slower rebound
    It's the same with motorcycle suspensions
    Reputation: SlipperyPete's Avatar
    Quote Originally Posted by GlenH
    Yep. It's the opposite of what you'd think it would be.
    This confused me too on my first bike with rebound control.
