Results 1 to 33 of 33
    Rush: Carbon vs. Alloy.
    Recently broke a Cannondale frame and have the opportunity to upgrade to the aluminum Rush or pay $1200 for the carbon version. I have tested the carbon rush, but have never been on the alloy rush. Is there much of a difference between the two frames? ...weight?...stiffness?....performance?...durabili ty?...
    I wonder if the carbon is really worth the price to upgrade.
    Reputation: sp3000's Avatar
    I can only add that the carbon is 300grams lighter, sorry I've only ridden the Alu.but I hear great things about the carbon.
    mad aussie
    Reputation: Flying Wombat's Avatar
    Other than the weight savings the carbon is also stiffer in the front end so it tracks a little better and seems to damp vibration more. No problems with durability with mine, I have had some crashes into rocks and rocks thrown up into the downtube and all I have to show for it are some scratches and chips in the clearcoat. Put it one way, I liked my alloy Rush, but I love my Carbon, its a better bike.
    I would suggest going carbon if you can stretch your budget to it.
    Kevin
    mnt bike laws of physics
    Reputation: yogiprophet's Avatar
    I agree with you Flying W. But I have one more thing to add. The carbon version has the option to use the SI cranks. These cost a bundle. I don't know what you guys think, but man these cranks are the friggin' deal. I would have a very very hard time changing bike companies after being spoiled by these babies.
    When I put them on I instantly got faster and I haven't slowed down since, so it wasn't just some new parts euphoria.
    If you have the doe, go for it all
    Which frame did you break?
    After driving to Fruita and Moab for a mtb vacation, I cracked the Jekyll on the very first ride. I was very fortunate that cannondale was in Moab after a race. A mechanic hooked me up with his carbon rush for the week. I was very impressed with the bike then. But I figured if the alloy frame was as good I'd get it and save a little cash.
    The rush would definitely handle the 4-5 hr weekend rides as well as an occasional 24 hr race.
    Do you think an XL frame could be set up close to 25lbs?
    mad aussie
    The difference in weight is pretty small between sizes, most of the weight is in the swingarm and the shock! Given a medium Team is 23.7lb with pedals an XL should weigh under 25lb easy with the right componenet selection.
    YP is right on the money about the SI cranks, definately worth going for as the outset. With the carbon frame if you put in the adaptor you cant (shouldnt) try to remove it. The BB30 cranks are stiffer, lighter and stronger, plus the bearings last longer and are less likely to be affected by water. After the Durango 100, 100 miles of sloppy mud, rain and river crossings my team mates XTR bottom bracket in his Scalpel was toast, my Si bottom bracket still runs as smooth as it did when I got it. Plus FSA and now Truvativ and both producing their own BB30 cranks so you have more choices.
    Kevin
    Are the SI cranks aluminum or carbon? What price range?
    My local bike shop has done a great job so far by putting together an component upgrade kit.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    SI = BB30, the crankset interface.
    Cannondale has 2 mtb SI cranksets, a carbon (made by FSA) and an alloy (in house, Cannondale made) model. The alloy one (Hollowgram SL) is the king of cranks, it's probably the lightest mtb crankset on the market, among the stiffest, durability is top notch (even better with the ceramic bearings) and it has the option of a triple, 4 bolts 104 BCD spider or a double, 5 bolts 94 BCD spider which is offset to give a better chainline than just a triple without the granny ring. If I recall, the Hollowgram SL is in the 600-700$ range though, not cheap but you are getting the Formula 1 of cranksets here...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    So, the integrated BB can't be installed after a traditional crankset/BB has been installed?
    Can a traditional BB be installed after an integrated BB was installed?
    Quote Originally Posted by wvnova
    The mechanic who loaned you his XL Carbon Rush could take the insert out that is installed so that a traditional BB can be put into the frame. BUT, it is NOT recommended for the average bike shop mechanic to do this.
    If the mechanics name is Troy, I rode one of his XL's also. He is the one who told me he could do it.
    Yes, an insert can be put in any time if you wanted to put in a traditional BB.
    My Carbon Rush is an XL and it is around 25lbs. It is def. light enough to be competitive in any kind of XC race.
    mad aussie
    I think the FSA is or shortly will be available directly (ie not Cdale branded) aftermarket as a K-force light unit, but wont be cheap. Unless you are interested in saving the maximum amount of weight the Carbon Si crank is cheaper but still a great crankset. I know it adds to the price, but it has so many advantages over the outboard bearing style especially for a larger rider that I would say try to go that way if you can.
    I have been so impressed with mine that I know my next road bike purchase has to have a Si crankset. I rode a Super Six this last weekend which was an impressive ride........
    Plus with other companies like Specialized going the the BB30 standard I can see it growing in popularity among manufacturers.
    Kevin
    I was planning to go to the local bike shop and settle up the frame replacement. But, I'm glad I waited. Thanks for the info about the frames and BB. Anything else I should consider before making the decision?
    I am considering the carbon lefty sl, but the left rlc made for a very nice ride. After 7 years on the Jekyll, either lefty would have to be better than the 70mm headshock.
    Cannondale Snob
    Reputation: RiskEverything's Avatar
    Mar 2006
    Can't the alloy version of the Rush run the BB30 crankset as well? IIRC the '06 Team Replica had just that...
    '06 Cannondale Rush 1000 4" travel 27lbs
    '04 Cannondale F600 SOBE -STOLEN!
    '96 Cannondale Uber-V 6" travel 30lbs
    Huge Tracts of Land
    Reputation: Mtbrat's Avatar
    carbon all the way, it is so much better
    Haven MTB Park
    1997 F2000
    2004 F4000 SL
    2007 Carbon Rush 1 Team
    I have the SL Lefty and it is sweet. I would think that the RLC would be smoother because of the coil spring. I did not have an option when I got mine and man let me tell you it would be a hard decision for me. I do like the ability to change the spring value at the stroke of a shock pump and the 1/2 a pound difference, but the Fox internals and coil would be soooo sweet.
    Does anyone have any experience with both?
    RiskE, The '06 T.R. was the only alloy Rush to have the BB30 frame.
    LA CHÈVRE
    Quote Originally Posted by RiskEverything
    Nope, when they introduced the Carbon Rush, they discontinued the BB30 alloy Rush... I'm hoping more and more frames will have a BB30 shell...
    mad aussie
    Given the adaptor can be installed and removed from an alloy frame fairly easily I wish that Cannondale would spec the oversized bottomb bracket through most of their lineup rather than just the high end. What we need is some mid range cranks to fit the BB30 system. Perhaps with its increasing popularity we may see it more commonly. The old system was designed in the days of square taper steel spindles and just doesnt accomodate oversized axles without going to stop gap measures like the external bearings which have inherent disadvantages in sealing, friction and Q-factor.
    Kevin
    Carbon Rush frames from Indonesia
    Has anyone checked into ads for Rush carbon frames from overseas, like this one: http://topbikera.en.ec21.com/product..._Carbon_Cranks
    This particular ad has a min order of 5 units at $600/ to include carbon cranks, fox rp23 shock.
    Reputation: Tackhammer's Avatar
    I've been planning for awhile to get the alloy Rush 5z as soon as my tax return comes in, now there is no way I can afford the carbon but after reading this thread it makes it seem like the alloy is not worthy - what's all this about bb30's and such? I'm not a bike guru or as knowledgable as some of you about these things, but is that a big deal? Is the alloy a good bike or not?
    Please help, I'm getting stressed.
    LA CHÈVRE
    Quote Originally Posted by Tackhammer
    The carbon is terrific but the alloy one is by no mean a bad bike, it's still great and while BB30 (it's a different bottom bracket standard that uses bigger pressed-in bearings and a bigger, stiffer and lighter BB spindle) is great, it's not an absolut must have for most... The alloy Rush is still a very worthy bike to get and many people here are very happy with theirs.
    I recently had the choice and chose Alu. An extra $1000 for 300 grams (maybe) of frame weight loss. Then there is the odd bottom bracket size. Talk about being tied in to Cannondale solutions (though I appreciate it is technically an interesting and light solution). I'd try not to get tied into a single manufacturer solution (yeah I don't have a lefty either )
    The bike will be down to around 25lbs with Fox forks and best of all there's no paint or carbon to scratch or chip (a real problem with my last bike)
    mad aussie
    I really liked my alloy Rush (it was a very good bike) until I rode a Carbon....... It replaced both the alloy Rush and Scalpel in my arsenal.
    Bear in mind that I race seriously, so saving a couple of pounds is a big deal to me. If you were trail riding with a few events on the side for personal accomplishment then an alloy Rush with a Fox would be a great choice. And most of us rode quite happily back in the day with square taper bottom brackets before we had Octalink, then ISIS then external bearing cranks and now BB30.
    Kevin
    Nov 2007
    New question here.
    Quote Originally Posted by Flying Wombat
    ...an alloy Rush with a Fox would be a great choice...
    No love for the Lefty? Or are you just referring to the lower-ended Rushes?
    mad aussie
    I like my Carbon SL but if someone was looking at the Rush 3Z I think the Fox F120 would be a good fork and work well with the bike. I may be a heretic but I dont think Cannondales HAVE to come with a Lefty.
    Kevin
    Quote Originally Posted by wellmt
    Good for you man!
    To clarify, most of us ride the carbon for the way it feels not just the mass difference. The [I]odd[I] size bottom bracket is only odd because other companies are not intelligent enough(yet) to know a great thing when they see it(or don't see it because the bikes are too damn fast). Besides there is no down side to the SI crank system. No maintenance to speak of. Only lighter and stiffer by far.
    The minute I saw a lefty I understood the benefit(being a physicist and engineer). Most other forks, such as Fox, are held up by only on side of the fork(by that I mean there is only a spring on one side). The only material that holds the 2 sides of the lowers together are the quick release and the small bridge above the tire. That is not much material and those forks flex noticable more than a lefty upon compression and rebound. The lefty's main tube is way huge and is supported above and below the head tube which in the end yields a much stiffer suspension torsionally and laterally. Now that you can get it with Fox damping, it is only a matter of price that makes it not a complete no brainer.
    Nov 2007
    Kevin
    Oh alright. I was just wondering what you thought, I have just been trying to get as much feedback as I can before I drop a little under 2Gs for a Rush 4. Have heard nothing but good things (besides a few lemons or user errors) about the Lefty. G'day.
    Kevin
    That is exactly what I was looking for. Thanks!
    Unicycles are for clowns
    Feb 2005
    The alum is great
    I had a choice (test rode both) and I picked the alum model, because of price and long term durability. I previously owned a scalpel, then got a Scott Scale Unlimited, and now have the Alum Rush. The scalpel was by far my favorite race bike ever. I did not like the Scale as Scott has odd sizing, it was very stiff and was not that "forgiving;" compared to titanium, steel, heck even some aluminum hard tails I rode were smoother. Plus after 4 months use the underside of the down tube had small nicks in the clear coat, which did not affect performance or the structure, but it looked more worn then it was. Seeing other carbon MTB's after long use and it is a similar thing - they look more worn do to nicks in the clear coat in certain areas.
    Mine is very close to being under 24 pounds (medium) and I was able to buy nice parts and still save lots of money which I can apply to tires, chains, and other parts that wear or may break during the race season. I don't think carbon frame MTB's are all that, granted they do look awesome, usually a bit lighter, and may be a bit stiffer; but are enormously expensive for very small gains. Lose 300 grams of body mass for free and that will be twice as much of a performance gain. By the way I am not knocking on those who own one, just giving some feedback from my experience.
    Quote Originally Posted by yogiprophet
    Good for you man!
    Now that's a great reply and thanks for the good fork explanation. I ride a carbon road bike and an alu one in the winter, so I appreciate the difference. To me the carbon actually feels a little dead Edit: I think neutral feeling is probably better (and of course it's much lighter). Some people would call that negating the road buzz I guess
    I'm not knocking Cannondale for being innovative at all. It's all good, I love the way that the company pushes the envelope. The BB30 is again a great idea. My point is that it's not a standard yet. The Lefty which is again is a great fork, is a Cannondale only solution with a proprietary front wheel hub and I don't want to be tied down with these Cannondale only solutions or spare parts. It doesn't help when Cannondale then go and have a batch of quality problems! (Lefty, Si crank, frames etc..) and I'm in the UK where service and spares is generally not that good. It's a shame as I am quite obsessive about bike weight but that's my compromise.
    Reputation: az1jeff's Avatar
    Feb 2007
    Let's not forget the obvious: Rush Carbon is made in Taiwan. Rush Aluminum is made in USA.
    jeff
    Well, I just worked with the lbs to complete the frame warranty replacement for my broken jekyll. With the carbon rush frame, I am upgrading to mavic slr wheels, the carbon lefty sl, easton carbon xc bar, xt front der/xtr rear der., and xt crankset, while keeping my juicy 7's, thompson seatpost, sram 990 cassette, and old xtr shifters.
    Would it be advantageous to stay with aluminum rush and put the $1200 toward new parts by upgrading the brakes to avid ult., the fork to the lefty rlc, and upgrade to the new shifters?
    I like the ride of the carbon frame, but I'm by no means an elite racer.
    I could possibly make one other upgrade: avid ult vs. carbon si crank.
    si cranks over avid ults any day, then save up for some formulas!
    Ok, after alot of thought I had the lbs order my warranty replacement frame. I decided on a '08 carbon rush. I was feeling pretty good about the decision until I read another cannondale post about carbon frames and their fatigue. I believe it was stated that deeper hiddenlayers of carbon can separate after impacts.
    Is this an issue any carbon rush owners have had with the carbon rush?
    I am beginning to second-guess my decision.
    I really like the quality of ride the carbon has, but I don't want to be purchasing another frame in a year.
    Maybe I can get the frame changed to alu' before it ships.
