I have a medium 2005 Rush 2000 with the RP3 on the rear.
Has anyone tried swapping the rear shock around so that the blue lever is located at the bottom of the shock on the front mount. i.e. switch the shock front to back and turn it upside down.
By doing this the lever would be a lot easier to get to, but I'm not sure if there is enough frame clearance and I'm sure someone had already tried it.
