Results 1 to 5 of 5
    Reputation: Fish on a Bike's Avatar
    Dec 2005
    New question here. Running a Lefty on a "Normal" Frame
    I'm sure this question has been asked before, but a quick search revealed nothing. So even though I'm sure my wallet would thank me for forgetting to ask, but is it even possible to run a Lefty on a "normal" frame?
    My current set up is a 2005 Specialized Stumpy FSR with 5.1" of fox talas travel. I really like my current frame, but the fork bugs me. It's not stiff enough and has some crappy play in the stanchions. I've test ridden the lefty on a 2006 Prophet and was impressed with its stiffness.
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    you will first have the reduce the c-dale 1.5" steerer to 1 1/8".
    depending on which model lefty you want, you can use pne fo the products below;
    http://cgi.ebay.com/Project-321-Cann...QQcmdZViewItem
    for alloy lefty max forks.
    or
    if you want to use a lefty carbon/speed fork with bonded clamps.
    also, you will need to make sure you current ht length will work with these clamp systems.
    crown to axle # (withOUT sag);
    my speed dlr2 110mm carbon fork is about 480mm
    my lefty max 140mm is about 510mm
    good luck
    "forget kings...forget hadleys......they all have crap engagement. just run your bike fixed gear." - FoShizzle
    Reputation: bpnic's Avatar
    Aug 2005
    I used the conversion kit with pretty good results.
    I'd hit it, but I bruise like a peach.
    Like catnip for people
    Reputation: ar1981's Avatar
    Quote Originally Posted by Fish on a Bike
    I want a picture...
    That would be priceless...
    Feb 2005
    Yep, Project 321 stuff is all it's cracked up to be. Several in use here, all excellent results!
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
