RST Deuce Shock Adjustments/Info
I'm wondering if anyone has encountered any good videos or articles on maintaining the RST Deuce forks. My lockout adjustments have stopped working at about 3 months of use (1600 miles though) and have been trying to find information on this fork without much luck. I've read of some other people having problems with this fork, and certainly in a perfect world I'd have replaced this immediately (or bought a higher end bike with better components), but I love Cannondale frames since they fit me really well...
I have the same fork, I would say replace it. It would probably cost more to repair it then what its worth. JMO
Should still be under warranty so I brought it up to the shop and they are putting in the request. It's a pretty crappy shock. I was under the impression that it was air shock, but the guy at the shop said it's an oil shock. I know it's heavy as hell and not a very tight shock, but hopefully the replacement will work a little better.
Ive been running that fork for a year and haven't had any problems with it, i have bottomed it out a bunch of times landing wrong on bigger drops and jumps, the suspension is about the only thing i haven't changed on my bike because its still working great.
I have the RST Air deuce on my trail sl2 29er. Are you saying that isnt an air fork or do you have the the sl4 deuce. I havent had any issues with mine other than its prob pretty heavy
My bike is the F5 (2010, 26in) and I thought it was an air deuce, but it doesn't say "air" on the fork and the guy at the shop thinks it's oil... Before this fork, I had a headshok from 1997 and I'm wishing I still had that fork. The stiffness of that fork made the bike feel much more responsive than this one. I'm contemplating upgrading to the DLR80 Fatty Headshok, but wanted to get a year out of the deuce and upgrade the wheelset first before tackling the fork.
The spring in the fork is air the damping system is oil, much like any other shock. I think your shop is populated by idiots if they can't work that out. Doesn't one of the top caps actually have "Air" printed on it?
If you can't get your lockout to work properly and your shop can't help you, I would suggest opening the system and adding 2 ml of suspension fluid to the system at a time and see if you can get the lockout working again. Lockout failure is usually caused by low oil level, and since the OCR lockout is an open bath lockout system you should be able to add a bit of oil at a time to get it working again. Actually, I would suggest you go ahead and just perform a full fork service since you have to open the thing anyway. Here is a link to the OCR system service video: RST
Of course, it doesn't list what the oil level is supposed to be for the Deuce in that video but I have contacted RST about it and I'll let you know if I hear back.
thanks for the info. Oddly, none of the caps say air on them but I think it's under the cap that says "preload" that allows you to adjust the rebound...
Edited because it appears that cap holds the oil...
I realize this post was from years ago but my rst Duece shock just gave out on me and I rebuilt it in about 30 minutes. If it's a simple lock out issue don't disassemble the whole fork you can take the lockout side off and add about 23 ml to get your lock out back. Keep in my mind that this is the lazy way but I'm getting a Bronson and don't have the cash to blow on a new fork just yet. I wouldn't recommend buying one, but for being stock I am pretty happy it's stiff and I and got 1500 miles out of it before the rebuild. YouTube "OCR maintenance" and you are good to go. BTW any motorcycle shop has fork oil for Half the cost.
good info.... I still ride that shock
What type of fluid should I get? What weight? Thanks
By HTail in forum Maverick
Last Post: 12-16-2009, 10:51 AM
By MONSONwarrior in forum Shocks and Suspension
Last Post: 07-29-2008, 07:21 AM
By Don 79 TA in forum Giant
Last Post: 04-19-2007, 01:22 PM
By Black4esT in forum Giant
Last Post: 02-12-2007, 07:52 PM
- You may not post replies
- You may not edit your posts
Forum Rules
