Results 1 to 9 of 9
    Jan 2005
    rockshox shock hardware on prophet
    hey guys
    wondering if anybody has done this or maybe has the correct stuff on thier bike already
    i have been using fox mounting hardware with a fox float for years but i'd like to try something different and perhaps better....the fox dimension are 8X37.59 and 8X27.43
    the closest thing i can find by rockshox is 8X38 and 8X28...just a hair wider but will that work ok without having to sand anything or screw up the shock mounts on the frame
    thanks for any help you can give me
    "He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    Monarch and Fox both use the same DU Bushing size, so it probably fits. You can always use the spacers from the Fox if the Monarch spacers are too tight.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    Just a flesh wound
    Oops!
    I just saw you wrote Rockshox. The Rockshox has a 12mm DU Bushing, not 1/2" like Fox. But the pivot bolt is the same for both the 12mm and the 1/2" (interior dimension must be the same), so you will still be OK. But I am sure that someone here who knows for sure will post up and confirm.
    Just a flesh wound
    You can tell I wanted to find out about this. The 1/2" width of the Fox translates to 12.7mm. So the extra width on the RockShox spacers is to make up for that .7mm. They have a bit less, according to your numbers, but it probably fits OK.
    Reputation: xluossa's Avatar
    Jan 2005
    what's really confusing...according to TF tuned website...rockshock makes some shocks with 12mm and some with 12.7mm (1.2 inch ie fox)
    Reputation: Duncan1104's Avatar
    The Monarch uses 1/2" reducers and DU's just like the Fox. As for width, the 28mm for the upper shock mount should be fine, but the lower are usually a little tighter tolerance.
    Rock Shox 1/2'' x 1/2'' Dämpferbuchsen 37,4x8mm für ein Dämpferauge, 3tlg. (#12640020) 1 Set
    # Rock Shox 1/2'' x 1/2'' Dämpferbuchsen 27,4x8mm für ein Dämpferauge, 3tlg. (#12640004) 1 Set
    # Rock Shox Monarch RT3 High Volume Dämpfer 200x50mm Tune-High Mod. 2011 (#12639237)
    This was mine order for this summer. New RT3 and pushings. Those are right sizes. Works great!
    Jan 2005
    Quote Originally Posted by xluossa View Post
    ahh, ok thanks...hopefully i can find those here in the usa
    prosit!
    (found them at Universal Cycles FYI)
  1. Prophet Rear Shock Mounting Hardware for Fox Shock
    By bdamschen in forum Cannondale
    Last Post: 03-26-2010, 10:19 AM
  2. shock attachment hardware 2005 prophet 600
    By scotte2981 in forum Cannondale
    Last Post: 02-07-2010, 08:31 PM
  3. Prophet shock hardware...............
    By nankerphelge in forum Cannondale
    Last Post: 06-27-2009, 03:11 PM
  4. Prophet shock mounting hardware?
    By bristolsurfer in forum Cannondale
    Last Post: 03-11-2008, 02:38 AM
  5. 5th element mounting hardware? rear shock hardware?
    By schoolisbad1 in forum Shocks and Suspension
    Last Post: 10-16-2006, 03:38 PM
