Results 1 to 3 of 3
    Rock Shox SID on Scalpel..
    whats is the "gate" knob on the fork supposed to do?? also has anyone experienced any creaking from your scalpel when u pedal? i thought it was the bolts that hold the shock together, any idea? thanx
    ballbuster
    Reputation: pimpbot's Avatar
    Gate...
    Quote Originally Posted by security58 View Post
    Is basically how much of a trail bump it takes to release the compression damper. Compression damper slows down the fork's compression cycle.. all the way on, fork is locked out, all the way off, it reacts quickly to trail bumps,but will bob like crazy if you crank out of the saddle. I run mine all the way open unless I want to lock it out since I ride seated most of the time. When I get out of the saddle, I lock it out.
    If you ride with the motion control compression all the way on, you can run the gate super high to make it like a full lockout, or super low so it slows the fork down and not bob, but it will let go when you get into bumpy stuff.
    I run my gate fully locked out, and use the compression opened or close as the lockout lever.
    You're probably going to get better answers if you ask this in the Rockshox forum, or the suspension forum.
    thx man, i hardly lockout my fork. so if the gate knob is open all the way, when fork not locked out, it still locks the fork until it hits bumpy stuff??
  1. Rock Shox Domain 302 vs Rock Shox Lyric
    By bome in forum Shocks and Suspension
    Last Post: 05-24-2011, 08:34 AM
  2. Fox rear shock or rock shox for scalpel ultimate
    By divingtigger in forum Shocks and Suspension
    Last Post: 03-30-2011, 06:43 AM
  3. Rock Shox FSX
    By Dhorn33 in forum Vintage, Retro, Classic
    Last Post: 09-17-2010, 09:16 PM
  4. Which fork:Rock Shox Recon 351 vs Rock Shox Revelation 426
    By stroker in forum Shocks and Suspension
    Last Post: 05-24-2007, 12:09 PM
  5. rock shox
    By SPEED129 in forum Downhill - Freeride
    Last Post: 09-28-2006, 03:15 PM
