    Oct 2007
    New question here. Rize - Some doubts
    Good Morning,
    I need your help
    On Monday i bid on ebay for 120 Rize aluminum frame and I can finally say that I have one!!
    Even I have not received because it comes from Luxembourg and i am from Spain, but I'm with the furnaces and want to go see that I need , so I require your help .
    I would need to know
    - Diameter of the seatpost
    - Size and type of the front derailleur
    - Type of adapter i need to put in the BB30 a shimano deore xt hollowtech crankset
    - Type of aheadset, type and diameter
    And one last question , which perhaps is an invention or nonsense. You can vary the route by changing the linkage , damper with another measure between eyes or career? ? ? In the Prophet at least if you play giving much more options.
    Can i chnage a rize 120 to a rize 140 by changing anything???
    Thanks in advance .
    Regards
    Reputation: chick0's Avatar
    Everything you need to know should be in the Manuals (rz120 / rz140).
    Manual mtb
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    You can go to pseudo-140 spec with a 140mm fork (or modded 120mm Lefty) and a long-stroke shock w/ 140 spec linkage.
    A few things I would do for longevity while you have the bare frame:
    1. replace the pivot bearings w/ Enduro Bearings.
    2. replace the swing arm w/ an RZ unit.
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    Oct 2007
    thanks for your answer.
    i am not going to chnage it now to 140, because i have a Cannondale Prophet in 160, but in a future if i sell it, i would like to have the posibility of versatility.
  1. Kona Cadabra 2010 weight doubts
    By MrR in forum Kona
    Last Post: 09-24-2013, 06:42 PM
  2. Kona Cadabra 2010 weight doubts
    By MrR in forum All Mountain
    Last Post: 08-03-2013, 11:49 AM
  3. Kona Cadabra 2010 weight doubts
    By MrR in forum Weight Weenies
    Last Post: 07-25-2013, 03:09 PM
  4. Trance 2006 , fork upgrade doubts
    By cerrogordo in forum Shocks and Suspension
    Last Post: 12-22-2012, 02:43 PM
  5. Niner - I have my doubts
    By honourablegeorge in forum Niner Bikes
    Last Post: 07-25-2011, 03:59 PM
