Results 1 to 1 of 1
    rize rz owners help! pivot problems.
    Got a used rize last year. What started out as a creak i coudnt find has now turned into a sloppy rear wheel. Crazy thing is i cant spot the knock. I read somewhere it could be the du bushing on the shock. But when i grab the shock and try to twist it it seems quite snug. The linkage bearing seems ok also. But i just cant place the source of the knock for the life of me. So im convinced its time to figure out how to do a full bearing replacement. Do i need to do the shock bushings also? I was thinking of doing rwc max bearings. Should i also do a needle bearing on the lower shock mount. i have read its not necessary on the top mount but is worth it on the bottom mount. Anyone have some experience with this or tips on what all i should replace andbhow to do it. I read somthing about a hairdryer for removal and loctite 638 for installation. Thanks to anyone for some insight.
  1. SB66 pivot bearing problems
    By shizzlebizzle in forum Yeti
    Last Post: 02-14-2013, 07:19 AM
  2. My Rize seatstay and main pivot bearings
    By danoalb in forum Cannondale
    Last Post: 10-02-2012, 01:48 PM
  3. Rize Seatstay Pivot/Bearing Design
    By tgoff in forum Cannondale
    Last Post: 04-23-2012, 04:21 PM
  4. Pivot 5.7's Owners...
    By oceanminded in forum Pivot Cycles
    Last Post: 06-03-2011, 10:36 PM
  5. 2010 Enduro Owners Front Derailer problems
    By SpecialWarr in forum Specialized
    Last Post: 02-09-2011, 10:43 AM
