Results 1 to 6 of 6
    Reputation: 220CROSSFIT's Avatar
    Oct 2011
    Rize rear triangle?
    Ok I just bought a rize that should be here on Thursday. It's a 2009 rize 4. I've been researching and I've seen some problems with the bearings in the seat and chain stay from the bolts loosening up. What should I check for when it gets here? What's the fix? Should I pull it apart and put blue lock tight on every thing? Does anyone know where I can get the torque specs from? Thanks for any help or advise.
    Oct 2010
    See if this helps you out. I have an 09 Rize 3 and have not had any issues.
    Attached Files Attached Files
    Oct 2011
    Thanks for the info.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    Follow the directions and you will be fine. Mine is still going strong since early 09 with no issues.
    Jun 2010
    check the torque on each bolt, it should be not less than 5nm. No need to disassemble it now.
    Oct 2011
    Thanks for all the replies. Really appreciated.
  1. Replies: 7
    Last Post: 07-05-2011, 08:01 PM
  2. Replies: 4
    Last Post: 09-11-2010, 12:07 AM
  3. Replies: 19
    Last Post: 05-27-2010, 10:06 PM
  4. 150 miles+Rize 2 Carbon = broken rear triangle
    By unit74 in forum Cannondale
    Last Post: 08-06-2008, 05:53 PM
  5. Enduro rear triangle vs. SX Trail rear triangle
    By Scary Mc in forum Specialized
    Last Post: 03-30-2006, 04:04 PM
