Results 1 to 12 of 12
    Reputation: chick0's Avatar
    Rize Carbon Large Frame-set - Stripped and Weighed...
    Was stripping down my Rize Carbon 08 size Large to give it a good clean and replace the pivot bearings and shock bushes, and while i was at it I put all the frame parts on some scales, here's my findings..
    Front Triangle = 1222g ( 2.69.lbs) - With BB30 to GXP adaptor installed..
    Seat stay = 196g ( 0.43.lbs)
    Chain stay = 695g (1.53.lbs)
    Hanger/ Bolts = 158g ( 0.34.lbs)
    Bearings = 58g ( 0.12.lbs)
    Shock bolts = 34g (0.07.lbs)
    Fox RP23 = 257g ( 0.56.lbs)
    Frame without shock = 2363g ( 5.20.lbs )
    Complete weight = 2620g ( 5.77. lbs)
    The Rize Carbon frame-set seems to be very competitive in terms of weight compared to other bikes in its class. For example, my friends Santa Cruz Blur LT Carbon also a Large frame-set, including shock, weighed in at 6.10.lbs.
    Attached Thumbnails Attached Thumbnails Rize Carbon Large Frame-set - Stripped and Weighed...-p1040089.jpg
    Rize Carbon Large Frame-set - Stripped and Weighed...-original-shock-bolt.jpg
    Reputation: nathanbal's Avatar
    I'm a little surprised actually. I thought it was closer to 2.4kg. the bb30 adaptor doesnt weigh that much...
    Reputation: 2DMaxLST's Avatar
    Great post, I have the 09 Rize Carbon One, it's refreshing to see direct empirical data posted on this site.
    2013 Niner RIP 9
    2012 Niner RIP 9
    2010 Niner JET 9
    Quote Originally Posted by nathanbal
    I would expect a Small size frame might get close or even be under 2.4kg??
    Or is it possible that the 2.4kg estimate that has been flying around is without shock?
    Quote Originally Posted by 2DMaxLST
    I thought some other nerd types like me would appreciate my findings
    Sweater
    Reputation: Buzzaro's Avatar
    I weighed my XL RZ120 aluminum frame (with RP23) before we put it together and it came in at 6.0lbs. Not apples to apples but just for comparison....
    All out of S**** and down to my last F***
    Thanks for the post. I think it's a good weight consider it's not a FULL carbon frame. Are the pivot bearings hard to take out?
    Quote Originally Posted by hypercycler
    3 of the bearings came out with a few firm taps with a punch, but the rest needed heated with a mini blow-torch. But once the Loctite had been warmed, they popped out with a few taps no problem.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    The BB adaptor is about 50grams... and white frames are the heaviest as it usually takes more paint to give a nice looking, opaque white.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Quote Originally Posted by Dan Gerous
    I will be taking out my BB adaptor in the next few weeks, so i will be able to confirm its true weight..
    I'm with stupid
    Reputation: hitechredneck's Avatar
    someone needs to do this with a large AL frame so i dont have to.
    Quote Originally Posted by hitechredneck
    I'm sure you bike is really needing a full strip down and cleaning session
    I would also be interesting to see how the other sizes compare too..
