Results 1 to 10 of 10
    Moven on
    Ridding it in DH position
    I mostly ride XC and rough roads with my Prophet. I got this bike in a very good trade, it's more bike then my abilities but maybe someday. I have been riding it in the XC position for about two months now, and decided to try it in DH position today. I rely liked the fill of being further back on the bike. It felt easier to lift the front tire up for obstacles, and it seemed to carve better in the corners.
    Will riding it in DH all the time cause any wear problums
    I was thinking about a shorter stem and more set back in the seat post, but changing the geometry cost me nothing and fixed most of my issues. I hope its OK.
    You got to ride um hard & put um away wet!!!
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    It has a XC setting and a FR setting, if you mean FR, no problems, many leave it that way all the time... if you really mean DH setting, did you drilled a third set of holes?
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Reputation: Duncan1104's Avatar
    the FR setting effect climbing at all?
    Reputation: Bubba74's Avatar
    Feb 2007
    Quote Originally Posted by Duncan1104
    A little bit. The front end wants to pop up a little easier up steep stuff than in the xc setting. I haven't noticed any difference in pedalling efficiency though.
    Apr 2005
    Riding it in the FR setting should not hurt anything! But I believe it lowers the bottom bracket height about one inch- which could mean crank/pedal collisions with obstacles a little easier. I just got a prophet frame and am currently building the bike, so I have been researching them a little bit- but at this time I am just spreading 2nd hand info.
    Reputation: The Orange Prophet's Avatar
    Quote Originally Posted by Dan Gerous
    Hell, I hadn't thought of that! A bit of grinding and welding might be required and the XC position may have to disapear all together but I'll give it a go when I get home tonight.
    It may be easier to change the stickers so they read DH & FR. You could then tell the ignorant that it was a one off developmental model.
    I had to switch mine back to XC from FR because of the lower clearance on the pedals/BB. I bashed my pedals a couple times coming around a corner while pedaling. It kicked my back end out enough to go off the trail which happened to be a steep creek bed. Luckily a well placed tree helped get me back on the trail. Just be aware you have less clearance than you are used to in FR.
    Lead by my Lefty............... right down the trail, no brakes.
    I find it works better in the FR position.....but thats just me i am more into freeriding and i love to do drops hucks and ride skiinnys..never been really good at climbing even in the xc position but my friend climbs on the FR position like a pro...so its all about ur skill not the bike...( it does help though)...as for cornering hold ur speed on the corner and pedal after.. or use caution..
    Reputation: Kevin G's Avatar
    Feb 2007
    I always have mine in FR setting; for climbs and "light" DH. A shorter stem and riser bars will help you get the full effect. Drop the seat and go! Just be wary of your components and what the bike can/can't handle.
    Moven on
    Thanks so much for all the feed back. I mistook FR for DH. DOOH Free ride seems so out of place. Nothing about Mt Biking is free, but maybe the exercise. I will be leaving it in the FR position until I start bashing my peddles or sprocket.
    Thanks again, ( boy, have I learned a lot on this web site). Thanks MTBR
