Results 1 to 30 of 30
    Reputation: StumpyElite2010's Avatar
    Reynolds Carbon wheelset experience
    I would like to get some feedback on the bundled Reynolds wheel-set.
    What's the weigh on those ?
    Will it be a good idea to replace the ZTR Arch 29er on my Flash 29 C2 ?
    TIA
    S.C. TB2
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
    Reputation: Flash29r's Avatar
    May 2013
    I have as set of those very wheels I purchased off of Ebay as brand new take off from the very same model you own. I have them on my '12 Flash 29 C3. I dropped 2 pounds with them over the stock wheels that came on my bike originally. My Flash weighs in at 21lbs with pedals and I am quite happy with that.
    As far as durability I have had no issues thus far and I tend to ride in some rocky areas. I had some loose spokes on the front wheel but since truing them I have had no issues and they are staying pretty straight for me. I love how the made the bike feel after I installed them. I definitely thought the bike felt faster. I am not a hammer type rider in that I don't ride abusive to destroy stuff. If you are and have had issues with wheels in the past then they may not be for you, but the feel pretty damn strong to me.
    Mar 2012
    I have around 200 miles on mine with zero issues.
    Big Damn Hero
    Reputation: CBRsteve's Avatar
    Quote Originally Posted by Matt116 View Post
    Same here.... very light and very stiff.
    Life is like riding a bicycle. To keep your balance you must keep moving. ~ Albert Einstein
    Glad to hear that these wheels are working great.
    Did anyone actually upgraded from Stan's ZTR Arch and can tell the difference ?
    S.C. TB2
    Flash29C2
    Reputation: limba's Avatar
    If you buy the wheelset get extra spokes now or you might be waiting when you break one.
    Mar 2012
    Quote Originally Posted by StumpyElite2010 View Post
    Yes I did and man what a difference. I didn't quite realize how bad the archs flexed and caused under steer in the corners until I rode with the Reynolds. For the first few miles I found myself over steering into the corners and would have to re-correct mid corner. I dont know what I'll do if the reynolds break and I have to put the archs back on.
    Nov 2012
    Love'm - Hate'm Reynolds 29er Carbon Wheelset
    Maybe this is also worth a read before pulling the trigger, quite mixed feedback....I have looked at these wheels for a while before deciding that there are seemingly too many issues with them. Apart from the lose spokes there are also quite a number of broken hubs.
    cheers
    grani
    Quote Originally Posted by grani13 View Post
    cheers
    grani
    Thanks Grani-
    Looks like too many people has serious issues with these wheels - although I am not the kind of guy that breaks frames or spokes, I'd rather spend the money on wheels that are more reliable across the board.
    S.C. TB2
    Flash29C2
    Nov 2012
    That's the thought I had as well...On another note: based on the research I have done it seems that the rims are really good. The trouble is rather in the built with the DT Evo spokes and the Reynolds hubs.
    Maybe i9 is the way to go as somebody in the above linked thread suggested. I am not sure though how much difference to e.g. Enves we are talking then...
    Mar 2013
    Got a set on my brand new Scalpel 29 carbon 1. Great bike and so much grief from the Reynolds, make me want to return the whole thing back to Cannondale.
    First the hub wend off spinning freely in both directions. My LBS replaced with new hub internals. Then the spokes started breaking out, one every ride. It became a routine of getting back to bike shop to replace a spoke after every ride.
    After 3 spokes replaced and complete rebuilt of back wheel, I simply left the set at the shop and replaced with aluminum wheelset. Waiting my bike shop to sort things out with Cannondale and Reynolds warranty.
    Stay away from them if you can
    gashgash1 - Did you call reynolds about that stuff? I had a couple broken spokes and they were really helpful, sent them to me right away, I've had them trued up and they are good to go since then.
    They offered that if I had further issues I could send them to them and they'd rebuild them for me. I have not had any problems.
    I don't get how you'd be breaking spokes every ride. Are they tensioning them properly? They are straight pull with alloy nipples so I believe you have to be really careful to not twist the spokes and put weird stress on them when you're tightening them. Could that be the culprit?
    On the rear hub, you need to take it apart and lube it, especially if you transport your bike outside your car in rain. I've done it about every 250mi or so or before every big race. The pawls will stick down and not engage after a bit. I don't believe they should need replacing, just a good cleaning/lube.
    Oaktown Honkey on Strava
    This all seems funny to me. WTB laser TCS 29er set for $300 shipped and I abuse them singlespeeding, and jumping at Tamarancho Flow trail. Never trued (there is a slight wobble after 200 rides) and I have never lubed. Flawless, and these are not even high dollar wheels. I bet money I am faster than 50% of people with carbon wheels as I ride 18 to 20 days per month. The other 50% I can ride past while they walk their bike to a shop.
    Trail Ninja
    Reputation: Varaxis's Avatar
    Quote Originally Posted by hoolie View Post
    ^ definition of blowhard.
    Have you guys seen the other reviews of this wheelset?
    Reynolds MTN AM Carbon Wheels Review - Pinkbike
    Reynolds AM carbon mountain bike wheels review - BikeRadar
    The Carbon Wheel Experiment : Reynolds MT 29 Wheels- Final Review
    Twenty Nine Inches: Interview With Paul Lew of Reynolds Cycling
    Actually just the facts. I like the idea of carbon hoops. ENVE was having problems with corrosion of nipples, Haven is notorious for bad rear hubs, and I was checking out this thread to see how Reynolds was holding up. Not ready for prime time obviously. It seems most issues are still with mountain bike wheels, not road carbon wheels. Anyway, I have the interest in Carbon hoops, and I will stick with Aluminum for another year. These threads are important for us, and I appreciate all of the honest stories about carbon rims, and any potential problems that may come up after spending $3000 on wheels.
    Oh, and post #13, I apologize for being snippy, but really, comparing $3000 wheels to $300 is realistic in this case. Me being fast, now that is tongue in cheek. I wish I could afford Carbon rims, knowing I MAY have an issue.
    Oct 2012
    I wonder if the problems people experience is due to the way the builder builds the wheels. Some people have great experience on Reynolds while others don't.
    I recently bought a Park tensiometer and basically rebuilt my cheapo wheel set. The spokes were constantly loosing up to the point I could turn them with my fingers. I haven't had any issues since retensioning them. I don't have many miles on them since so maybe I should say anything, but I just wonder if some sets come out of the factory built better.
    This would apply to any brand. It's been my experience if the wheel isn't tensioned properly, the spokes may continue to loosen up and you will continue to have problems. I assume this is with any wheel.
    When I picked up my new bike in the autumn sales, my LBS told me to ride them hard (I am about 100 Kg) and then bring them in for a rebuild once the snow arrives. Nothing wrong with the wheels other than poor build quality on a higher than normal set of wheels according to LBS. I have had no issues so far.
    T.
    May 2013
    I know with the set that I have initially they used way too thin of a gauge of spoke along with alloy nipples. I tried to get my rear wheel fixed after loosing a spoke and taking it to the LBS for repair. They ordered the spokes from Reynolds, but were still not able to get the wheel straight due to some tight tensions on the rest of the wheel. I ended up sending it back to Reynolds and they relaced the whole wheel. While I had it there I asked them to take a look at the freehub since it had slip marks on it from the cogs. When I got my wheel back the only thing that was original on it was the rim. They used a heavier gauge spoke and replaced the hub as well. I figured a new free hub, but they replaced the whole hub. All that being said they have excellent CS and I would not hesitate to tell anyone about buying any of their wheels. My total cost for the rear wheel repair since I had no sort of warranty was $98. $50 of that was in shipping cost alone since it was insured both ways. If your wheels are under warranty you should pay nothing more then for shipping. I would call them with any issues for they will work with you.
    I noticed C'dale moved to Enve wheels for 2014, sounds like a good move
    Oct 2012
    I just read the love'm -hate'm posting referenced in this thread and I see they too mostly agree with my earlier post:
    Good parts doesn't necessarily equal Good build.
    I've read Easton tensions their wheels according to the pitch of the spokes when plucked. I've also read that Eastons stay strong and true for a long time. Maybe that's a result of their Quality Assurance program when building.
    I may be buying a set of Reynolds Carbon which is what brought me to this thread. If I do, I'm going to check the tension on all the spokes as they come from the factory and I will post my findings. I'm not a wheel building master, but I figure if the wheels are mostly true and evenly tensioned it's probably a good build.
    Quote Originally Posted by ironsinker View Post
    I was the OP on the love'm-hate'm thread. Initially the wheels were less than satisfactory, and the aggravation of getting them sorted out was beyond acceptable, after nearly 6 weeks of going back and forth with the LBS and Reynolds everything finally got sorted out. The rear wheel was sent back to Reynolds and it came back re-laced and tensioned correctly. From that point forward the wheels have been bullet proof. I raced 7 of the MASS endurance races, a few local XC races and trained all year long on the wheels without a single issue. They are still true and roll perfectly smooth. I'm selling the Scalpel 2 that they came on but I'm keeping the wheel set to put onto my new Scalpel as training wheels. I'd estimate that the wheels have nearly 1400+ miles of hard racing, training and everyday riding on them and they are as good as new. I think the initial issues were more of a build/ assembly problem then design issues.
    Reputation: albertdc's Avatar
    Re: Reynolds Carbon wheelset experience
    I got a Scalpel Carbon 1 this fall that came with the Reynolds wheels. After only a few rides, I broke a spoke on the rear wheel. Still rode out no problem. Got a replacement from Reynolds and it trued up fine, but once winter hit, my wheel went to Reynolds. They rebuilt it with a new hub, spokes, and nipples. No charge. They said there was a design flaw in the hub so the spokes were being stressed and apt to break. Supposedly, the new build will hold up better.
    Sh!t happens - at least they are taking care of the problem.
    Sent from my SCH-I545 using Tapatalk 2
    May 2013
    Quote Originally Posted by albertdc View Post
    That may be why they replaced the hub on my rear wheel when I sent it back. Did you notice there was also a thicker gauge spoke in them from what you sent it out with? I know mine has a heavier gauge spoke now then before.
    Quote Originally Posted by Flash29r View Post
    Yes. Heavier/ thicker spokes too. Just measured: 20-18-20 gauge butted spokes. Pretty sure they were 16 gauge (or maybe 15 - is that possible? ) instead of 18g before the rebuild. Kind of bummed about the added weight because they are my race wheels/race bike. Then again, a broken spoke would cost me a heck of a lot more time than the heavier spokes. I didn't weigh them before I sent them out, so I don't know how much more the thicker spokes weigh.
    Trail Ninja
    ^ The lower the gauge number the thicker it is. You mean 2.0mm and 1.8mm?
    Gauge = spoke thickness (rounded to nearest tenths)
    13 - 2.3mm
    14 - 2.0mm
    15 - 1.8mm
    16 - 1.6mm
    Quote Originally Posted by Varaxis View Post
    13 - 2.3mm
    14 - 2.0mm
    15 - 1.8mm
    16 - 1.6mm
    Dooh. Yes. Exactly. Insert a decimal point and change gauge to mm in all my measurements above. :banghead:
    ...something didn't seem right as I read writing that, but I couldn't figure out what.
    Just got mine back from Reynolds. Same as the rest, new rear hub and thicker rear spokes. I'm not sure but the front spokes may be thicker as well (same front hub).
    I've been very impressed with the customer service, as well as the wheels when riding, just the initial build durability and the pawls sticking in the freehub. That hopefully will be fixed now, if not I'll send them back inbetween races.
    FWIW, I did about 900mi on them last year and several races. At no point last year were they unrideable except when I broke spokes, but those were quickly taken care of by dealing with Reynolds. I expect to do that + another 50% this year if the season goes to plan.
    Oct 2010
    Quote Originally Posted by thechickencow View Post
    thechickencow, Reynolds just did the same for me but I don't have the wheels yet, just a tracking number. I had the same breaking spoke and freehub issues that others have had. I was wondering if you have been riding your hopefully improved re-build and if you've broken any spokes or had any other issues.
    No issues, I'm about 300mi in on them. Tension is all fine and no hub problems. I think I'm good to go.
  1. Reynolds AM Carbon Wheelset
    By MarkMass in forum Wheels and Tires
    Last Post: 11-11-2013, 08:30 AM
  2. Any reviews of the Reynolds Carbon Wheelset ?
    By StumpyElite2010 in forum Cannondale
    Last Post: 12-18-2012, 11:02 AM
  3. Reynolds 2012 XC Carbon Wheelset...
    By cohenfive in forum Wheels and Tires
    Last Post: 11-05-2012, 12:25 PM
  4. $999 Reynolds carbon 29er wheelset
    By danK in forum Where are the Best Deals?
    Last Post: 05-28-2012, 08:28 PM
  5. Reynolds carbon wheelset for $700
    By CCPHammer in forum Wheels and Tires
    Last Post: 01-19-2011, 03:56 PM
