Results 1 to 2 of 2
    Jun 2012
    Replacement for Trail SL2 29er fork - suggestions?
    I've had my Trail SL2 29er, 2013 for about a year. It's got a 1.5" steerer, not tapered (if I'm honest I'm not 100% certain what that means) , which I now understand is not common, so could be problematic to replace, as I think the existing Recon Silver, 80mm, has seen better days.
    I'd like a little more travel, and always found the Recon a bit stictiony.
    Can anyone suggest what I can do/get as a reasonable replacement.
    Can I assume a budget of 400 uk?
    Chris
    Sent from my GT-I9300 using Tapatalk
    The Fastest of Bananas
    Reputation: FastBanana's Avatar
    Aug 2013
    you dont have to run a 1.5 inch straight steerer. they make headsets that will adapt your current headtube to anything you could want to run.
    That is a good budget to work with. I would suggest a Manitou Tower (check pricepoint) or a Rockshox Reba. Both are solid forks. and stiction is a result of not servicing your fork unless it it utter garbage.
    Sent from my LG-LS995 using Tapatalk
  1. Suggestions for a 120mm trail/am fork
    By sbd in forum 29er Components
    Last Post: 12-06-2012, 07:16 AM
  2. 2006 Rocky Slayer fork replacement suggestions
    By cocamoxb in forum Rocky Mountain
    Last Post: 03-29-2012, 08:46 PM
  3. aspect 29er fork replacement
    By Petey123 in forum 29er Bikes
    Last Post: 03-01-2012, 07:31 AM
  4. New 29er fork suggestions.
    By kikoraa in forum 29er Components
    Last Post: 02-03-2012, 07:34 AM
  5. 29er fork suggestions
    By dkebones in forum 29er Bikes
    Last Post: 02-13-2011, 08:39 AM
