    Reputation: J273's Avatar
    Removing a 2 piece lefty stem/steerer
    Not long had my flash which came with a 2 piece stem and steerer. Ive just bought a XC3 Si integrated stem/steerer which is 90mm rather than 110 which should fit me a little better.
    Ive removed the stem and undone the 2 pinch bolts on the fork but for the life of me cant figure out how i get the steerer bit out
    It just seems to spin - can anyone tell me how i remove the steerer?
    This is where im at thinking this would be an easy job
    Many thanks
    Mar 2013
    Cannondale Ernie Lefty Steerer Tube Install Tool - KT020/ - CannondaleExperts.com
    But ive heard people getting away with using a D-cell maglite body
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    You can just buy a 90mm stem and save the trouble of taking everything apart.
    What Jersey 29er said. But since you bought the XC3 Si, you will have to remove the front wheel to get the steerer tube out. Use a rubber mallet to knock it down thru the clamps. Once below the top clamp, I've had to use a round piece of wood and tapped around the steerer until it was out. I've also heard of someone using a piece of PVC pipe. The XC3 will be installed from the top.
    '16 Cannondale Scalpel Carbon 2
    '15 Niner SIR 9 SS
    '14 Cannondale F29 Carbon 3
  1. removing spacers ( stem) on a Stumpy FSR
    By Devastazione in forum Specialized
    Last Post: 08-19-2013, 06:14 AM
  2. Stem clamp diameter for tapered steerer? What brand of stem?
    By Muffinhead in forum Beginner's Corner
    Last Post: 08-29-2012, 06:31 PM
  3. Lefty XC3 OPI SI Stem/Steerer Install
    By mevadus in forum Cannondale
    Last Post: 04-07-2012, 12:50 PM
  4. Bad Boy One-piece stem/bar?
    By Mobiker7 in forum Cannondale
    Last Post: 01-27-2012, 07:23 AM
  5. Replies: 56
    Last Post: 08-26-2011, 12:43 PM
