Results 1 to 24 of 24
    Reputation: freeriderB's Avatar
    New question here. reducers for Prophet headset - swapping Lefty
    I'm swapping the Lefty Max 140 for a traditional 1 1/8 fork.
    Can I just use the current headset "cups" on my prophet, and just buy 1.5 reducers?
    Or do I need an entire new 1.5 reducer headset?
    thanks.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Two options:
    1- Buy a reducing headset that you press into the frame, not in the SI headset.
    2- Get 1.5 to 1.125" reducing cups and use a regular 1.125" headset.
    I might be wrong but I don't think there are reducing adaptors that will fit inside the SI headset and let you run a 1.125" fork right there... I think you are stuck with getting another headset. In that case, I would go with option 1, less parts, less creaks, less flex, less pressing to do.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Reputation: bbbr's Avatar
    The Problem Solver reducers sit in the SI headset cups and from there you press in your new headset cups. They're not a press fit and i can disassemble the ones have by hand quite easily. Doesn't give me a warm fuzzy feeling with that much slop in the system.
    Get a reducing headset, less hassle and trouble
    Alea Jacta Est
    I'm going to be converting from my lefty to a 1 1/8 fork also, but to be honest, I don't know exactly what all I'll need, can anyone tell me what I'll need and maybe suggest a few brands?
    Cane Creek, FSA and E-Thirteen all make a reducing headset to get you from 1.5 to 1.125.
    Cane Creek also makes one called the Double XC for the older Cannondale's that have the a shorter press depth than the 1.5 standard calls for.
    Alea Jacta Est
    Prophet converted!
    Reputation: F3caffeine's Avatar
    How much does it cost, roughly, to swap a lefty for a comparable regular fork?
    Well, you have to buy a reducing head set, a new fork, and a new whell/hub because lefty uses some weird one.
    Prophet converted!
    Quote Originally Posted by Syndrome
    Sorry for the dumb questions, but i'm new to all of this. About how much would that stuff cost? And would the brake calipers fit on a different fork, or would they need to be replaced? Thanks for the help.
    Feb 2007
    Quote Originally Posted by F3caffeine
    My leftover Lefty BB7 cable pull fit right on a Dirtjam pro front fork on my Chase. No mods. As far as pricing goes......I'm pretty sure you have access to the internet.
    Would this work for Prophet?
    FSA Big Fat Pig - 1.5'' - 1-1/8'' Reducer Headset
    * The FSA The Big Fat Pig headset features a 21mm headtube insertion and is constructed of aluminum/CrMo.
    * Forged chromoly cups
    * 21mm headtube insertion
    * Chromoly crown race
    * Laser etched aluminum top cap
    * For 1.5" size
    * Stack height 16 + 13.5 = 29.5mm
    * Lower cup uses super durable 7/32" bearings
    * Weight 176 grams
    * Black anodized finish
    http://www.ride-this.com/FSA_Big_Fat...020210037.html
    (other than it is Out of Stock)
    Or any other not $100 reducer headsets?
    Reputation: rw420's Avatar
    Dec 2005
    Quote Originally Posted by nonojoe
    Yes.
    Any one point five headset will work in any newer C'dale frame.
    Reputation: SlipperyPete's Avatar
    Check out this link. The FSA Pig reducer is what I use. It's heavy; but so am I.
    http://www.universalcycles.com/shopp...7&category=502
    Yes, I like that and the price is right!
    Reputation: Karve's Avatar
    Mar 2006
    Quote Originally Posted by rw420
    Yes.
    Can someone just qualify that? I though Cannondale head tubes were not 1.5 but some odd measurement like 1.56 or something daft..
    Could I reduce it with something like http://www.chainreactioncycles.com/M...?ModelID=25722
    Dec 2005
    Quote Originally Posted by Karve
    Cannondale uses a 1.5 headtube on all their current models. What you're thinking of is the difference between a 1.5 steerer tube and a Cannodale headshok/lefty steerer tube. Although the headtubes are the same, the forks and headsets are slightly different.
    Dec 2005
    yes
    Mar 2006
    Excellent.. thanks for clarifying that.. does make life a bit easier
    Back again
    I just had my head shock changed to a trip crown. The LBS charged me $40 for the reducing headset and $20 in labor. A lot of times I think I'm just better off letting the shop do the work.
    triple crown?
    Quote Originally Posted by Coop
    Triple crown on what...a Prophet?
    Isn't that a little overkill?
    What did you go with...Boxxer, 888???
    Just wondering, never saw a Prophet with a DH fork.
    Killer of Chains
    Is there a difference between 1 1/2 headsets and 1.5 headsets?
    For Example:
    This one and one/half
    and
    This One point five.
    Feb 2007
    No assuming you realise that one of your examples was a reducing headset to fit standard 11/8 steerer forks. What are you wanting to do?
    Reputation: gweb's Avatar
    I was hoping to use the Hope 1.5 stepdown headset http://www.chainreactioncycles.com/M...?ModelID=18085 in my 2006 Prophet, but Hope seem sure it will not work. Has anyone tried this headset in a prophet?
    Killer of Chains
    I'm wanting to run my Pike instead of my Lefty.
    Mar 2005
    Did hope say why it wouldn't work? Newer Cannondales (pretty sure this includes your prophet) run 1.5 standard headtubes. The older ones weren't designed to take the longer insertion specified for 1.5 headsets, hence the need for something shorter like the cane creek double xc short. But the newer frames are ok.
