Results 1 to 3 of 3
    Reputation: wrxsti08's Avatar
    Rear shock question - Rize 1
    Hey guys, i'm new to this board. I hope you can help me out. I'm planning to change the rear shock on my bike for the DT-Swiss XR Carbon. I was wondering which dimension you recommend me between the 190mm/50mm of travel or the 200mm/55mm of travel? My futur bike is a Cannondale Rize 1 (ordered it on april) with a Fox RP23 '08 shock and has a 50mm stroke and 200mm eye to eye.
    If i get the 200mm with the 55mm of stroke would it fit on my bike?
    Reputation: Duncan1104's Avatar
    55mm stroke would probably work, but then your lifetime warranty most likely will go out the window.
    Quote Originally Posted by Duncan1104
    ok maybe i should stick with the RP23
