Results 1 to 6 of 6
    Rear Brake reaplacement with the Lefty
    I'm trying to replace my brakes and the front is GTG. When I get to the back brake I can't fit the lever or the caliper through the opening between the headtube and lefty. Are they any tricks out there without removing the lefty completely or opening up the brake system ?
    Moderator Moderator
    Reputation: driver bob's Avatar
    Not that I know of but removing the fork is not a big deal.
    But it looks like i have to have the Special tool from cannondale and the BB tool for the bottom lock ring, to do it correct ?
    Reputation: thatdrewguy's Avatar
    It seemed easier to disconnect the brake hose since I was going to trim the hose length anyway and then bleed the brake.
    Sweater
    Reputation: Buzzaro's Avatar
    I've taken the hose off at the cylinder before without needing to bleed the brakes.
    All out of S**** and down to my last F***
    I have recently shortening my formula break hose without bleeding.
  1. Front brake vs rear brake
    By Ladmo in forum Brake Time
    Last Post: 01-25-2013, 07:51 AM
  2. Recommend a disc brake adapter for my Lefty
    By mevadus in forum Cannondale
    Last Post: 04-10-2012, 02:53 PM
  3. Lefty fork Rubbing/catching on brake caliper
    By ozbikebuddy in forum Cannondale
    Last Post: 10-15-2011, 01:52 AM
  4. 29er Singlespeed wheel reaplacement ??
    By 96p993 in forum Singlespeed
    Last Post: 06-22-2011, 11:30 AM
  5. Disc Brake Conversion - rear stay brake line?
    By RBatsch in forum Litespeed
    Last Post: 04-03-2011, 02:50 PM
