Results 1 to 12 of 12
    Real weights Cannondale bikes
    Post the real weights of our beloved Cannondale stock bikes.
    2013 F29 carbon1 (medium frame): 9,41 kg - 20,75 lbs w/o pedals
    2013 F29 carbon2 (medium frame): 9,765 kg - 21,53 lbs w/o pedals
    Source: CANNONDALE F29 CARBON 1: SE SOGNATE DI ESSERE FONTANA, QUESTA E' LA VOSTRA BICI - pianetamountainbike.it
    Foto e peso reale della Cannondale F29 Carbon 2 | Bersekt MTB Rider
    Eh. That sounds a bit strange. I'm quite sure my F29 Carbon 1 size L weighed less than that. It's about 9.35 without tubes, but with XTR pedals and a bottle cage.
    I'm going to get smaller discs and another saddle, hopefully that will drop at least 150 g.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    There will always be variations in weight from one bike to another (heck, a tire in the same size and model can vary by as much as 50+ grams so with the variations of every components... you do the math).
    Also, most of those kind of balance are not the most trustworthy, lots of variations there too so unless you use the same balance for each bikes, don't take the numbers as absolutes but more to get an approximate weight range...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Happy Trails
    Reputation: Scott In MD's Avatar
    Scalpel Ultimate with Maxxis Ikon 2.25 tubeless, 180mm front rotor (replacing 160mm), Arundel carbon cage, Garmin 500 computer and XTR pedals >> 23.1 pounds on a calibrated scale. This was about 5-1/4 pounds lighter than a similar setup on my aluminum FS bike, a 2008 Titus 29r.
    I Fought The Lawn
    Reputation: The Hired Wrench's Avatar
    Nov 2008
    I posted this a bunch, but, if it's for science....
    2013 F29 Alloy 1 Size Large
    11.28 kg, for the rest of the world.
    '15 Lapierre Zesty TR429
    '13 Cannondale F29
    '99 Schwinn 4 Banger
    '98 Manitou FS
    '97 GT LTS-1
    Reputation: fondoo's Avatar
    Sep 2012
    my 2013 jekyll 3 medium weights a whopping 31 pounds. the only thing i upgraded was the ergon saddle and have wellgo b124 flat pedals.
    2013 Cannonale Jekyll 3 M
    My large F29 Carbon 3 was 22.7lbs out of the box (without pedals and front rotor fitted). Pretty light for a stock bike.
    Dec 2012
    2014 XL frame Cannondale Trail SL1 29er
    Stock weight 28.57lbs / 12.96kg
    (note that this is with the supplied stock black Cannondale pedals - they're heavy, I'd guess 550g+)?
    Upgraded weight: For info, bike weight with pair of Crossmax XL 29 wheels with WTS Quest 2.35" tyres, plus SuperStar El Plastique Nanos = 27.18lbs / 12.33kg.
    The saving of 0.6Kg is probably 200g from the pedals, 430g from the wheels, although this is with MUCH larger WTS tyres than the Cannondale supplied low volume WTB nineline tyres and, with slimmer tyres on, we'd drop another 300+g further from the wheels), so would be closer to 12.05Kg (26.5 lbs).
    Tyre weights
    Quest tyres 29x2.35" = 1740g pair (+100g? sealant) = 1840g
    WTB Nineline 29x2.0" = 1074g pair (+ pair tubes @ 450g) = 1524g
    Reputation: Nubster's Avatar
    My carbon 3 F29 with carbon ATAC pedals in size XL is 20 pounds and some change on a bathroom scale. That's after changing it to 1x10. Taking off the 2x parts dropped 13 ounces off the bike.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    Norco Torrent HT 7.1
    2015 F-Si Carbon Black Inc, frame size M, converted to SRAM 1x with a 32T front ring, eggbeater Ti pedals and arudel mandible cages: 9.2kg
    Reputation: Flash29r's Avatar
    May 2013
    2012 F29 Carbon Large frame. Not really stock anymore as you can tell from the pics. Getting under 20 lbs I will be chasing grams and reliability will probably suffer going for super light stuff. I am content with this weight for now.
    Attached Thumbnails Attached Thumbnails Real weights Cannondale bikes-img_20150710_232008016.jpg
    '12 Flash 29r C3 with a few mods
    '10 Synapse 5 Carbon with a few mods as well..
  1. XC Race bike real weights
    By sevencycle in forum Weight Weenies
    Last Post: 07-14-2013, 10:24 PM
  2. i23, arch ex, blunt real weights
    By Z-Man in forum 29er Components
    Last Post: 12-18-2012, 08:10 AM
  3. Real World Weights: Lyrik Solo Air & Lyrik Coil?
    By myitch in forum All Mountain
    Last Post: 03-25-2012, 08:42 AM
  4. real weights for 29er bikes
    By robopopp in forum 29er Bikes
    Last Post: 02-19-2012, 09:58 PM
  5. First REAL bike - Cannondale SL4 vs Trek Mamba
    By Rugae in forum 29er Bikes
    Last Post: 10-04-2011, 04:28 PM
