Results 1 to 3 of 3
    Jun 2010
    Question about stem sizing for Bad Boy Solo
    I'm in the market to lift the angle of my bars/stem. My goal is to lift my posture up a bit so I'm not slouched over so much when i ride. Now my BB Solo comes with a 100mm x 5 degree headshock and wanted to know where I can get one that fits with a 20 degree angle. Also, being that i am raising the bar a bit should i keep the same length or increase/decrease the length to compensate for the lift. hope this make sense. TIA
    Aug 2005
    a riser bar might help too? (or as well)
    for any parts, your local cannondale dealer, or general bike shop, should be able to order parts and install them.
    good ski/bike deals at www.mntlion.com
    My life is better than your vacation.
    Jun 2010
    i thought of a riser bar as well. The stem with a 20 degree lift should do fine. Plus its ha;f the cost of going to a riser. I may do that as well if the stem doesn't work. Anyone know if i should shorten the stem if I go with a higher degree, or should I stay with the same length. TIA
