Results 1 to 32 of 32
    Quality Mountain BB30 Bottom Bracket?
    Can anybody suggest a BB30 bottom bracket that seals well against water intrusion? The OE bottom bracket on my Trigger 29er seems to be getting water into it and sometimes it will lock up if the bike sits after being ridden in muck, or even washed.
    Reputation: Flash29r's Avatar
    May 2013
    How are you washing it, with a pressure washer or a hose? If pressure washer that is a bad idea since it forces water places it should not be. I personally have not had any water intrusion on my BB30 on either my Flash or my Synapse. FSA SL-K cranks on both.
    No pressure washer, just a hose. I generally don't spray right at the bottom bracket either. This is a SRAM crank, maybe the bottom bracket isn't as good on this?
    May 2013
    Nothing really special about the BB really, just pressed in bearings. Maybe the SRAM bearings that came with those cranks are low quality. You could just get different bearings from else where and see what happens after that. You may be able to even spec the bearings McMaster or some other place online. I plan on doing that once I use up my supply of current bearings.
    Feb 2005
    Sadly, I see a metric sh*t ton of BB30 mtb (and road) bikes needing service on the BB at least once a season, if not several times.
    I've not seen nor heard of anything that fixes it other than buying a bike that doesn't have the silly system.
    Better quality bearings may *help* with contamination issue on the bearings themselves, but they still creak like your grampas knees after a few months of riding.
    Yet another "advancement" that really nets nothing for the end user besides more headaches.
    I'll get off my soapbox now
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    May 2013
    Quote Originally Posted by MendonCycleSmith View Post
    I don't doubt you have seen a lot of these go bad, but the one on my '10 Synapse has been very quiet and no issues what so ever. I have heard nothing out of the one on my Flash Carbon either other then to say I did replace one bearing due to clicking from it going bad, but never creaked at all. I must be lucky I guess.
    Jan 2013
    I too have seen a ton of BB30 bearings in rough condition. On mountain bikes the rough bearing condition is nearly always due to too much washing and not enough drying/maintenance. The latest case of rough BB30 was a 2011 Cannondale Claymore with no drainage hole under the BB.
    The stock BB30 bearings from FSA for example are not too shabby with sealing. You can see grease films forming on the edges of the seals even when the bearings are not stuffed full of grease, so you can bet that they also suck in water and crud fairly easily.
    Riding without a rear mudguard is fine and dandy, but pointing a water hose to wash off the crap behind the seat and seatpost is a bad idea, especially with a BB30 bottom bracket.
    The seatpost area leaks in suprisingly large amounts of water unless you made sure the seatpost can't let any water in from the top and that the seatpost/frame contact point is well greased/antiseized and/or you have sealed it up with say an old tight inner tube slipped over the frame/seatcollar/seatpost area.
    Couple the water intrusion with a trend of less and less drainage holes under the bottom bracket on modern bikes and you will be bathing your BB30 in a pool of dirty water you just washed into your frame. The Claymore I mentioned in the start of this post had sand inside the frame and clear water line marks of where the level of water had been. Half the bearings were under water after a wash...
    So my advice is to either seal up the seatpost area properly or avoid washing the seat and seatpost on the bike.
    Make sure the BB30 bearings are properly stuffed with good quality bearing grease. If you wash and forget I honestly suggest some marine bearing grease that is made to run under water.
    After a good wash just leave the seatpost out of the frame and let the inside of the frame air dry. Might hasten the process to pour out extra water from the frame if any of it got in.
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    I drilled a weep hole in the bottom of my frame at the BB. Tons of water/crud goes down the seat tube and needs an escape port or it will contaminate the bearings because it has nowhere else to go.
    I just replaced my FSA BB30 bearings w/ Enduro bearings. Slathered everything w/ grease to create an additional moisture barrier.
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    Mar 2013
    While my BB30 RZ 120 doesnt creak at all (using a retaining compound during installation), I have noticed water gets in way too easily.
    a few months back I disassembled everything for servicing and right before I gave it a light spray (more of a mist)... and I mean LIGHT! I misted the bike with water, then used a light bristled brush to knock the dirt off, then misted the bike to get the soap off. When I removed the crank about an hour later, there was a small puddle of water pooled between the two bearings at the bottom bracket. I suspect water gets in elsewhere and settles at the lowest point.. the bottom bracket. Because the BB30 has open bearings, the water enters, where other BB systems are closed off from such water intrusion.
    I hardly ever wash my bike (but maintain the drivetrain very well), so thats why my bearings probably last longer than others.
    Music & Bikes
    Reputation: fokof's Avatar
    Quote Originally Posted by Stumpjumpy View Post
    +1
    I leave my bike upside down after I cleaned it up for a couple of minutes to avoid this.
    Water get out by the seat post or by the hole I drilled under the BB.
    "There is a big difference between kneeling down and bending over" -FZ
    Any suggestions for a replacement bearings then? Stock SRAM bearings haven't lasted well. I think in my case it's more from riding in much and crud than washing, it's been a wet year.
    Mar 2013
    Quote Originally Posted by ALS650L View Post
    Ive got some ABEC 5 in my RZ from here: BB30 BOTTOM BRACKET BEARINGS FROM REAL WORLD CYCLING
    Mar 2011
    Just get some of ebay ?10 30 X 42 X 7mm 6806 2RS Sealed Model Ball Radial Bearing 30 42 7 | eBay
    Remove sealing using needle and press full of some quality grease in there. I use Motorex 3000 and have no problems even after some really muddy races this season.
    Helmetless Crasher
    Quote Originally Posted by SandSpur View Post
    That's what I got . . .
    I'm covered under warranty still. Going to throw in a set of stock bearings for now, they will get me through this season easily. I may put some better grease in first however.
    Happy Trails
    Reputation: Scott In MD's Avatar
    2013 F-29er has a weep hole.
    IMO, water in the BB on early models is probably a problem. But .... It is what it is ..... so take care of your bike and get the water out if you have a design that collects water.
    Mar 2013
    Quote Originally Posted by Scott In MD View Post
    which ones have weep holes? both alloy and carbon? or just one?
    I did notice even some of the chinese direct carbon frames are even putting weep holes in their bottom bracket shells.... so that should say something about how known water collection in that area is.
    May 2013
    My '12 Flash Carbon 29r has a hole as well. Hell, my '10 Synapse carbon has a weep hole also! I guess Cannondale thought of that when building these bikes with the BB30 setup. I have only replaced one bearing since having these bikes and I believe the one I replace was one I screwed up once while reinstalling it. Beyond that they have worked very well for me.
    Put in a new set of SRAM bearings, FSA is what came out. I removed the seals and packed them full of waterproof automotive wheel bearing grease. It's very thick but I think it may work better, we'll see.
    Time for new bearings again. Going with a stainless steel version this time. Certainly didn't get many miles out of the OE SRAM ones. Anybody found any that last yet?
    Mar 2013
    I have 2 years on my BB30 bearings.. still not creaking, still working perfect... still not washing my bike
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    I rarely wash my bike, that's not the issue. I also don't ride in wet much and avoid mud. Bike is stored indoors too.
    Reputation: MarinCRO's Avatar
    Jul 2013
    What I've noticed is that if I remove the bearings from the frame, they're smooth, but putting them back in makes them rough.
    Seems like tolerances on BB30 are bit tight and BB shell squeezes them enough to create drag and possibly alter their geometry shortening their lifespan?
    I just took the crank out and cleaned and greased every thing. There isn't signs of water intrusion in the frame like the last set of bearings I did. Frame doesn't have a drain hole. I'll see if cleaning and greasing helped. I did order new bearings however.
    May 2013
    You do know you don't have to buy them from SRAM or FSA? You can just get the number off the bearing and order them elsewhere. Even through McMaster. Nothing special about them, just what bearings they use. You may be able to source them through other places as well.
    '12 Flash 29r C3 with a few mods
    '10 Synapse 5 Carbon with a few mods as well..
    Quote Originally Posted by Flash29r View Post
    I'm aware of this, work on cars for a living. I ordered some off ebay, just bearings, no spacers and clips. It rained last night so I won't be able to take the bike out until tomorrow anyway, did some gravel grinding on my single speed today.
    Just an update. My bottom bracket bearings were pretty smooth but I replaced them anyway. Still creaky, traced it to the Shimano XT shadow plus rear derailleur. Not sure what the fix is yet.
    Jaymanjibe
    Nov 2012
    My Trigger 29 has had a nasty bottom bracket creak as well. After rebuilding the BB30 bottom bracket twice with no results in getting rid of the creak I finally solved it.
    The non drive side of the SRAM S1400 cranks has a dust cap/bolt that I tightened up with a 10mm Allen and the creak is gone. It is the bolt/dust cap that says "Do Not Remove" engraved on it. Finally, the creak is gone!!. It was not the BB30 but the non drive side crank/axle interface.
    Jul 2013
    I had creak as well and recently bought 30T NW chainring for 1x10 setup.
    Changed the chain and lubed spindle on the non driveside crank arm.
    This and/or new chain fixed the issue.
    Its interesting you bring this up. I found the do not remove bolt on my crank a bit loose too. I also have a S1400 crank on a Trigger 29er. If you remove that bolt does the crank arm come off easily? I'd like to grease that interface to see if it helps.
    Jaymanjibe
    Nov 2012
    I am not sure what the do not remove bolt does. I could not find any exploded views of the crank assembly/construction to see what it does exactly. I just tightened it up as tight as I could. I am just glad the dreaded creak is gone (for now anyway)...
    Reputation: Nubster's Avatar
    Anyone ever use a conversion to run external crank bearings like the Praxis Works?
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
  1. Bottom Bracket Standards - a guide to BB30, PF30, and Outboard Bearing compatibility
    By e-luder in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-25-2016, 04:10 PM
  2. Replies: 4
    Last Post: 07-23-2013, 04:08 PM
  3. bb30 bottom bracket pressed into a Pressfit 30 (PF30) frame
    By trail rida in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2013, 10:19 AM
  4. Replies: 4
    Last Post: 02-15-2013, 08:19 PM
  5. Creeking BB30 Bottom Bracket...what could it be?
    By chikai in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-07-2012, 08:32 PM
