Results 1 to 12 of 12
    ganginwood
    Reputation: ganginwood's Avatar
    Mar 2005
    pumping the lefties.....all of them
    is it just on my forks (3 lefties) or on all later models, that the shock pump won't register a preassure. on my latest bike, i can't remove any air with a standard shock pump.
    i also can't get accurate preassure readings on any of my forks. the valve needle is too high into the stem. the shop says they're all coming like that. what gives?
    below is the wifes bike.... just finihsed putting it together. unfortunately i have to use a scott shock pump to register/remove any preassure becuase it has an adjustable adapter on the nozzle. i have to return the pump soon. anyone have something that works?
    Quote Originally Posted by Mike Aswell
    the 5th poster, ganginwoods, is correct
    Reputation: HAL 9000's Avatar
    Eko Sport Air Tight SV Shock Pump Adapter solved my problem
    Ground Pounder
    Reputation: MrHappyMedium's Avatar
    Feb 2007
    The Topeak PocketShock works great for me on my Lefty Speed 110, Float R and Float RP23.
    My bicycle gets more dirt than your 4x4.
    I have the same issue on my 08 Rush 4. My shox doesnt read unless I thread it on really really tight. I tried another pump and it was the same deal.....
    Reputation: Yuengling's Avatar
    Quote Originally Posted by XtoZ
    I have the same problem with my 2006 Speed DLR. It has to be TIGHT to get a reading and add/remove air.
    Cannondale Caffeine 2 29er
    Redline Monocog Flight 29er
    Fuji RC Team
    Kona Jake the Snake
    Blk Mrkt Mob
    Nov 2007
    here are some tips Can't Air up my Lefty
    Reputation: rumshcawheely's Avatar
    This is a problem that has been know for quite some time now and cdale will replace the part at no additional fee. Just take it to you cdale dealer and tell them to call cdale's tech dept. and in a week or two you'll get your replacement valve assembly. It's real simple to change.
    I use a Fox shock pump and have never had a problem in my '07 Lefty Carbon SL 110...just make sure to fit it tight (not ultra tight, just as tight as you would go with any other pump I guess) and it should work fine.
    Reputation: Tinshield's Avatar
    Why is your wife's bike thrown in the bushes?
    ganginwood
    Mar 2005
    Quote Originally Posted by Tinshield
    not sure.. need to ask her. its usually me she throws into the bushes.
    Quote Originally Posted by ganginwood
    Mine throws me under the bus.
    Nov 2007
    Quote Originally Posted by andygua
    Sure, none of us could figure that out, thanks a lot for that advice...
