Results 1 to 8 of 8
    Jun 2010
    Prophet what size front deraileur to order?
    I was going to order a front deraileur Shimano XT for a Prophet and was curious what size clamp and if it is bottom pull or a top pull?
    Reputation: 2004sahara's Avatar
    u need an e type, the kind that mounts using the bottom bracket. Some guys have ground away material from the swing arm to make a clamp on fit with out hitting but not a good idea
    Can't stop the Prophet
    Reputation: brows141's Avatar
    Exactly what Sahara said. This is the E-type derailleur you will need. $40 bucks on Jensonusa.
    Attached Thumbnails Attached Thumbnails Prophet what size front deraileur to order?-fd306a03.jpg
    That is the one im getting!
    Jun 2010
    okay thanks for the fast response.
    No prob
    If you got a dual ring setup...
    Get the M665 SLX e-type. The cage is shorter and won't rub on your rear tire when in the granny. If you got a triple, the XT e-type would be the one for you.
    Quote Originally Posted by Kealoha
    Good point
