    Prophet mx1 isgc question
    My mx1 has iscg old tabs,it came with a 11-13 chain guide.The guide is mounted on a adapter for b.b mount.I bought the bike used,is this stock chain guide ??
    The adapter pushes the guide out a few mils away from the frame.Can I remove the b.b. adapter and mount the guide directly to the iscg tabs,or use the less complicated blackspire iscg old chain guide and just bolt it directly to the frame
    I will set the bike up as a single middle ring 1x9 ....see pictures below
    Attached Thumbnails Attached Thumbnails Prophet mx1 isgc question-p1090705.jpg
    Reputation: Duncan1104's Avatar
    Yes, you can remove the adapter and bolt the chain guide directly to the ISCG tabs as long as the chain guide is the same ISCG old pattern as the MX's.
    Does anyone run a chian guide on there mx1,if so how is it set up
    Quote Originally Posted by AMCAT
    Could you be a little more specific? I'm not sure what you mean exactly.
