Results 1 to 9 of 9
    Prophet MX chainguide
    Hi there, I've got an '06 Prophet 2MX, I'm looking to fit a dual-ring chainguide. Will I need to cater for the e-type deraillleur, or are the ISCG tabs recessed enough? I know that the e13 DRS and MRP LRP both have options for e-type derailleurs, but I'm thinking I can get away with the "regular" ISCG versions of both.
    Thoughts please, and any examples of what you guys are running on your MXs or 4Xs.
    Cheers!
    i dont hafe a mx.... but with e13 you cant go wrong!!
    ride.
    I run a Blackspire Stinger. It is 1/4 the cost of the LRP by MRP, and is basically the same thing. ISGC mounts are fine, it just takes a bit to line it all up. If you already have the der installed it will be a breeze.
    I'm using an E13. ISCG mounts don't line up when you attach the e-type to the backplate and bolt it to the frame boss, but it doesn't really matter; just sandwich the guide plate between the BB flange and shell.
    Cheers dudes - NS-NV, you're running the Stinger OK with the e-type der? Did you have to space the BB differently with the Stinger installed on the ISCG tabs? Ta
    No. The BB stayed the same (X-Type). I replaced one spacer with the E-Type. The rest stayed pretty much the same. I may have messed around with the spindle spacers, but in the end the chain line worked fine.
    Yes the Stinger was mounted on the Tabs. I am pretty sure it was not an ISGC 05.
    Thanks mate :-)
    do you guys find you're dropping chains much on the mx? I just ordered one and was considering going w/o a chainguide, although I do prefer them on most of my bikes. just curious...
