Results 1 to 8 of 8
    shaved yeti
    Reputation: bonkey's Avatar
    Prophet eye 2 eye and stroke
    Hey y'all,
    Prophets.... 7.875 x 2 or 7.875 x 2.25?
    Thanks,
    Kong
    Too old to ride. Too young to die.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    It's 200mm x 50mm, so 7.875" x 2"
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    discombobulated SuperModerator
    Jun 2005
    Keep your mitts off that one. Its mine, I saw it first. No one bid....
    I'll explain in 2 days, 19 hours
    CDT
    Killer of Chains
    What else can we fit with relative ease?
    Something longer or shorter? I assume we cannot fit a 2.25 because its too wide right?
    I dont know anything about rear shock dimensions on bicycles.
    Jun 2005
    Quote Originally Posted by PaintPeelinPbody
    Well if the eye to eye is the same, it'll fit. Thing is if its 7.875x2.25 stroke, will it hit the seat tube upon full compression?
    I am sure someone in here has tried this....?
    CDT
    LA CHÈVRE
    With a 2.25" stroke, you must keep the bike in it's XC geometry to avoid hitting the seat tube with the rear tire. You need to stay with the right eye to eye measure though...
    Quote Originally Posted by Dan Gerous
    Hey Guys!,
    I was thinking about that too so when I would buy a rearshock that has 2.25 stroke but still the right eye to eye lenght then it would give my bike more travel in the rear right ? (I would have to keep it in the XC setting of course)
    The thing is that I switched the Pike with an Lyrik on my prophet 2 MX so i have 160mm up front now but still "only" 140mm in the back.
    If I would make that change would you guys suggest a coild in the back ? such as Marzocchi Roco WC or a Fox ?
    Right now i have a RockShox Pearl 3.1 [Air] ive never ridden anything else than air in the back so how big is the difference to a Coil in the back ?
    A 2.25 stroke shock should give you 159mm of travel in the rear. A coil would definitely feel plusher and easier to tune. I've got a coil on my Gemini that will fit. If I ever get time I put the coil on to see how it feels.
