Results 1 to 5 of 5
    Reputation: pin-it's Avatar
    Prophet DHX Air size
    I need to get a dhx air shock to evaluate it. What size is correct for the prophet? 7.875x2.0?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    It's 200mm eye to eye x 50mm stroke in metric.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Quote Originally Posted by Dan Gerous
    Thanks Dan, that's what I need. Can't wait to try one of these things out.
    Edit: in terms of mounting hardware, will the same bolt and spacers from my swinger work with the fox model?
    LA CHÈVRE
    Quote Originally Posted by pin-it
    I don't know but I doubt it, different companies, different shaft diameters, different eye width... Check the technical specs for both shocks.
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    I do not think so.
    Just check the Fox website for the hardware part #'s, or measure the gaps on the frame and swingarm (in mm) yourself.
    gfy
