Results 1 to 6 of 6
    Can't stop the Prophet
    Reputation: brows141's Avatar
    Prophet/Avid Ultimate brake line assistance needed
    J.C. I just got off the phone with my LBS who are in the process of putting together my prophet. I bought a set of Avid juicy Ultimates for my bike but unfortunately the brake line for the rear brake is too short.
    Give me a quick fix as the bike shop is at a loss. They are proceeding with the build minus the rear. This is where I need your help, fellow Prophet owners and or B.M.'s. I remember reading somewhere on MTBR of another person having a similar issue but I do not remember the solution.
    ANYONE???
    Feb 2005
    Short term? Run 'em Moto style (reversed), but be careful
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Quote Originally Posted by MendonCycleSmith
    Yeah I thought about that, will have to see tonight when I go to the BS.
    For some reason I thought that they would be able to change out the hose that was too short.
    Fixin' shocks Day & Night
    Reputation: two6labs's Avatar
    Nov 2008
    Check distributors and other local shops. Avid makes that hoes in 3 different sizes 1400, 1450, and 1600. Mine came with the 1400 and it was real short, I ordered the 1600 trimmed it just a bit and it fit perfectly! Good luck.
    Tim
    IdontShootPeopleAnyMore
    Reputation: DriveByBikeShooting's Avatar
    i had a similiar problem with my avid exlixir CR's that I had put on my bike like 2 months ago. the back was just a little too short for my prophet and so my LBS ordered the longest hose from avid which solved the problem but it is still a little shorter than i would like but it is 100% ok...
    What mountain bike forum do pirates use? .....
    MTB-arrrrrrrrrrrrrrr
    Reputation: MTB Moe's Avatar
    This is just an FYI, alot of brake manufacturers will kit 1400mm hoses with 160mm rotor sets 1450-1500mm hoses with 185mm rotor sets, and 1600mm hoses with 203mm rotor sets. When I ordered the Elixir R rear set of my Rush the folks I bought it from swapped a 185mm rotor for a 160mm and shipped the rear 185mm kit containing the longer hose.
    No cutting and Bleeding.
    Moe
    <--Thats Me
    Cdale Flash 29er Carbon 3
    Cdale Flash 29er 2
    Cdale Scalpel Lefty
    Cdale Rush Lefty (2)
    Roots
    Rocks
    Raggae
