Results 1 to 2 of 2
    Aug 2005
    Prophet 600,800,1000, or 2000? For best proj.
    I will slowly build my bike into the perfect custom, but none of these models have just the right equipment. (duh) which of the models has the most potential? for instance, I am thinking of the 2000 because it comes with the carbon lefty and Ti axle which seems to be the same fork as the 4000 and team. (plus it may be very expensive to upgrade to these later) Am I right? does the 2000 have the best potential or should I get the 600 so I will have the maximum amount of money for upgrades? Thanks
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    The 2000 and the 4X Carbon Leftys don't have the Ti spring, that's it. Check everything you want to change and calculate from each model's MSRP and see what the best deal is. Or get just a frame and fork and build from there...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
  1. Prophet 2000 @ 25.5 lbs???
    By Caleb in forum Cannondale
    Last Post: 10-30-2004, 10:43 AM
