Page 1 of 2 12 LastLast
Results 1 to 100 of 130
    Post your Taurine
    Hello, I 'm Steven from Belgium and I 'm new around here. Finally got an account.
    So, as I said: let's post some Taurines!
    Here you can find some pics of me latest bike. It took over 5 months to get the bike...
    http://i3.pinkbike.com/photo/1406/pbpic1406306.jpg
    http://i4.pinkbike.com/photo/1406/pbpic1406307.jpg
    http://i5.pinkbike.com/photo/1406/pbpic1406309.jpg
    http://i1.pinkbike.com/photo/1410/pbpic1410522.jpg
    Some specs:
    Frame: Taurine Carbon SI (framekit)
    Fork: Lefy Speed Carbon SL 110 DLR2
    Wheels: Mavic Crossmax SLR
    Tires: Schwalbe Nobby Nic
    Pedals: Crank Bros Eggbeater 4Ti
    Crank: FRM CU2 M27
    Chain: Sram PC991
    Cassette: Shimano XTR
    Derailleur front: Shimano XTR
    Derailleur rear: Shimano XTR
    Shifters: Shimano XTR Rapidfire
    Bar: Ritchey WCS Carbon flat bar
    Grips: Ritchey WCS
    Bar-ends: C'dale Ultra Light bar ends
    Stem: C'dale XC3 Team stem
    Headset: C'dale Headshok Si
    Brakes: Hope Mini's met floating discs v:160 - a: 160 mm
    Saddle: Sella Italia SLR Kit Carbonio flow
    Seat post: Ritchey WCS Carbon
    Color: Team Replica
    Weight: 9,04 kg
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Looks fast standing still! You have a great, lusty bike... but it's way too clean.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Still working on that...but it 's very hard to find some mud...
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    Reputation: SlipperyPete's Avatar
    No mud in Belgium?
    Nice bike! That thing must fly.
    With the 4Ti's
    Does your heel/shoe ever hit your crank? I am thinking of trying the 4Ti's but due to my leg physiology, I need to have my heel turned in a bit on my right foot and I am concerned that the short spindle on the crank brothers will cause my heel to hit the crank on every revolution.
    My Large Taurine weighs 19.84 with EVERYTHING - bottle cages, etc.. I will post pics soon. It is the best handling bike I have ever owned. I give credit to the incredible lefty and the stiffness of the frame. Hard to justify a dualie when this frame mutes the trail vibration so much.
    ONLY complaint is that the BB is so low I hit my pedals on roots, etc.. (Time ATAC Pedals). Thinking the crank bros would give me a little more clearance. Also, my rear Racing Ralph in a 2.1 size is more like a 1.9 and I only run 31psi - so I think going to a RR 2.25 will raise my BB heigh a bit. Catching your pedals can put you into the trees hard - no fun. So I need to fix this.
    Reputation: rumshcawheely's Avatar
    Steve that bike is nice. But, what's up with the FRM cranks? Seems sac religious to take off the great SI cranks and put those on!! I had a set of those things come apart in a race. Where the spindle is fixed to the driveside crank arm, just pulled right out. I read that many others had the same problem. Some people were threading the spindle and using a fixing bolt similar to the non drive side to fix the problem. Just thought I'd let you know.
    -Chase
    LA CHÈVRE
    Is it any lower than most racy hardtails? You can't just pedal without taking rocks and roots into account, sometimes you need to slow or stop your pedaling a bit to go through some sections, it's always been one of the skills needed for mountain biking, on full rigid bikes as with skyscraper tall FS bikes. It wont be better with the eggs, they are not that much lower profiled and worse, they often release your foot when they hit something. They are still the best pedals even with that slight negative point but it's another reason to avoid banging them everywhere...
    LA CHÈVRE
    I found the crank choice odd too... I'd get a Hollowgram SL with only two chainrings on that bike...
    About the crank choice... I 've bought a Taurine frame kit (frame + Lefty); the sublime Cannondale SI-crank is not delivered with the kit. Off course, I wanted that crank, but it costs about 1000 Euros (1300 USD / 680 BP) when bought seperately... Even me C'dale dealer said it was too much... So, it became the FRM.
    @jtc1: there is still a bit space I guess to turn your foot in. I think the biggest problem will be the small space between your heel and the chainstay...
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    Quote Originally Posted by Dan Gerous
    Thats exactly what I thought when I saw those pics...It looks like it will go ride the trails by itself while you are at work.
    BB height
    As measured it is a very low BB - and then with the low profile tire and low air pressure, I think my set-up is unusually low. Sure, a race bike will have a low bb to improve handling, but to be at risk for so many small stumps hitting the pedals it can actually cost lap time. I am coming from a Turner Nitrous - so I was a little spoiled in being able to just pedal through everything. I think just going to a larger rear tie will give me just the little bit of height I need.
    Still cant get over what a stiff frame fork combo this bike is - and the carbon mutes the trail buzz so much I just dont feel there is much advantage to a short travel dualie anymore.
    What chainrings are you running?
    Still original...the FRM's...
    Will be soon replaced by TA Specialités.
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    italian globetrotter
    stem
    which stem are you using? seems a 100 -5 degrees. it's right?
    ciao
    thanks
    LA CHÈVRE
    I also have a question but about your bar ends. Did you weigh them? And are they available from any Cannondale dealer yet?
    Yep, that 's the one. I 'm considering a 120 mm (or 110 mm when possible).
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    No, I didn't weigh them... It should be about 60 gr. I bought these bar ends mid April...
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    LA CHÈVRE
    Quote Originally Posted by stevenvde
    I found out they are rebranded Smica/Post Moderne bar-ends... around 60gr indeed, I found some Smica for super cheap, no Cannondale logo but still, they are the same light bar-ends and they were cheap.
    My C'dale dealer told me the same...
    Great bar-ends: nice design, light and efficient stuff to use. These bar-ends will also be mounted on my GT...
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    LA CHÈVRE
    I personnaly like the fact that, as opposed to most bar-ends, the mounting bolts are toward the back, away from where you actually grab them.
    Some updates:
    - Schmolke carbon flat bar SL
    - Schmolke carbon seatpost (in back-order - will be delivered soon)
    - Tune Speedneedle
    - Shimano XTR Shadow
    Road set-up... I often use the bike for the ride to my work...
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    Nice Taurine, when the weather's good I'll take some pictures of mine. I was thinking of getting an XTR Shadow, but I've read a few posts saying they have problems with the arm spring coming off. Have you had any problems.
    I put the Shadow on the bike about 3-4 months ago and still no problems at all. If adjusted properly, it 's a pleasure to ride with.
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    that seat looks downright painful..."needle" is appropriate. ouch.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    some taurines on www.eliflap.it
    i owned 2 taurine ...
    very well-done frame , a weapon on track
    I rather be cycling...
    Reputation: mtymxdh's Avatar
    Jan 2005
    ... and if we just ...
    be careful of high winds, you may see your bike going away like a feather...
    that got to be a light bike...
    <- im sooo jealous
    Languages spoken: bicyclish, spanish and a bit of english
    http://www.youtube.com/watch?v=FJy_GDpbRvk
    New question here. bottom braket
    i love my taurine but there are some minor issues:
    • my taurine Large BB is so low that i hit the crowns almost at every ride!
    • rear brake mount flexes a little bit too much and sometimes squeaks (or even craks -just sound)
    • the steer angle is a little bit too steep (also with lefty) and the bike is a little bit to much nervous.
    feel free to comment this points!!
    Quote Originally Posted by michelefiorentin
    • my taurine Large BB is so low that i hit the crowns almost at every ride! Yes, happened already a few times. The 'low' 1.8 Schwalbes are one of the reasons, as well as the positions of the bb.
    • rear brake mount flexes a little bit too much and sometimes squeaks (or even craks -just sound) never noticed it before...
    • the steer angle is a little bit too steep (also with lefty) and the bike is a little bit to much nervous. So, it 's a perfect match...I am a bit nervous as well... Bike can be a bit nervous, that 's true, but still easy to control
    Grtz,
    Steven
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    LA CHÈVRE
    The Taurine is not a trail cruiser, it's a full on XC race bike so a low bb and steep head angle is to be expected. As for the rear brake, I would suspect a mis-align caliper, caliper adaptor before the frame... Might be worth it to take the caliper off, the adaptor off, clean everything including the bolts and re-install.
    More than somewhat.
    Reputation: Cypress's Avatar
    [*]my taurine Large BB is so low that i hit the crowns almost at every ride!
    What does this mean?
    LA CHÈVRE
    Quote Originally Posted by Cypress
    Crowns:
    More than somewhat.
    What if I don't have crowns? Will I need them after my bike arrives?
    LA CHÈVRE
    Nope, you're lucky, you have less chance to hit them on every ride.
    oof
    lonely
    This is my taurine awaiting me at the shop. I'll pick it up in a week or two. Let's see some more.
    stay calm
    Taurine
    My Taurine, excuse the mudguards, but I've been doing some commuting lately.
    Hope to get lighter brakes at some stage. These are quick bikes for racing.
    More than somewhat.
    This link needs to be placed in the "post your ******* sticky.
    Me and the fastest bike I've ever ridden:
    She's a dirty girl.
    Good job! my english is sooo bad
    hi taurins (who owns a taurine ),
    I think I wongly translated the italian word "corone" into crowns...
    sorry for that, I learned something today... and I get some fun too!!
    as far concerns the BB, the discussion is pretty open as the one regarding the concept of XC: I ride pretty complex trails with tecnical rocks and trees on my way. My old cannondale fx 700 was some way taller and i can clear them easily. Somebody in this discussion talked about this issue so I wanted to give my opinion about...
    then my crowns are broken!!
    have fun
    More than somewhat.
    After going on three rides in 2 days, I must say, this is the fastest bike I've ever ridden.
    It feels faster than my road bike (LOOK 565). Going downhill is helluva fast. Just need a longer stem, as climbing with the front wheel on the ground is harder than you would think.
    Here's mine
    Just finished building yesterday.
    oof
    nice. The black looks alot better with the lefty for some reason. There is a black one with a headshok at my shop, but it doesn't look nearly as nice. I think it's the silver of the clamps and the cranks (from another bike?).
    stay calm
    More than somewhat.
    The bike looks like an '07 paint scheme. Explains the silver cranks.
    oof
    aah, you're right. I thought they went black with the hollowgram in 07 for some reason.
    stay calm
    More than somewhat.
    Here's my french taurine 1SL 2008
    http://www.pinkbike.com/photo/1937532/
    More than somewhat.
    1. I've never noticed the low BB. If I suspect something might come close to my chainrings, I avoid it like Neverland Ranch, or get off of the bike.
    2. I don't think I've ever used my rear brake to the point where it would flex. It's a Taurine, not a trials bike.
    3. Nervous? The Taurine descends better than most FS bikes I've ridden. The Lefty is the most confidence inspiring XC fork I've ever ridden. I rode my friend's SID after being on the Lefty and felt like I was going to break it.
    Reputation: HAL 9000's Avatar
    [*]rear brake mount flexes a little bit too much and sometimes squeaks (or even craks -just sound)
    i can't speak for the canondales but the two scott sparks that i've owned had the same issues of the frame making crazy noises when the rear disc brake is applied forcefully.
    it's a lotta stress on those seatstays and the combo of the brake mount pop-riveted to the frame and the brake forces make those carbon tubes put out some weird cracking noises sometimes.
    also keep your bike clean nothing brings out unknown noises like a dirty sweaty bike.
    Reputation: baalan's Avatar
    Nov 2007
    How long is that seatpost?
    '96 Uber Light
    '00 R3000 TT
    '08 Six13
    More than somewhat.
    Mine is a 350 or a 400. I have 250mm (exactly) sticking out of the frame, and I'm nowhere near the max.
    Hello Steven,
    I'm also new @ this forum
    Here are some pic's:
    http://www.pinkbike.com/photo/1837976/
    http://www.pinkbike.com/photo/1837966/
    http://www.pinkbike.com/photo/1836136/
    http://www.pinkbike.com/photo/1841162/
    http://www.pinkbike.com/photo/1837971/
    latest update specs 09-05-2008 (pic's are older than some specs )
    Frame: Taurine (second frame, first had a crack after 2 month)
    Fork: Lefty Speed Carbon SL DLR 110 (88+ tuned) (1175gr)
    Wheels: Mavic Crossmax SLR (1580gr) + FRM M Team ltd gold (1390gr)
    Tires: Continental Speed King Supersonic (410gr) + Schwalbe Furious Fred (315gr)
    Tubes: Maxxis Flyweight (93gr) + Stan's Notubes
    Pedals: Crankbrothers Candy4Ti (201gr)
    Crank: XTR with Acros BB (ceramic)
    Chain: KNC SL Gold (9spd en 10spd) (221gr + 240gr)
    Cassette: XTR 11-32 + Dura Ace 11-24 (159gr)
    Front der.: XTR topmount
    Rear Der.: XTR shadow mid cage with KCNC gold ceramic jockeys (180gr)
    Shifters: XTR Dualshifters with NOKON der. routing
    Bar: FSA K-Force flatbar 31.8mm (128gr)
    Grips: Fizik Bar:Tape white (17gr)
    Bar ends: KCNC (50gr)
    Stem: cannondale SI one piece stem/steerer 31.8 (with ti bolts)
    Brakes: XTR calipers + Stan's Alu rotors 160mm (61gr) with Hope 6# ti bolts (7gr)
    + Hope floated disc 160mm (90gr) with Hope 6# ti bolts (7gr)
    Saddle: Selle Italia Filte Kit Carbonio white (155gr)
    Seatpost: Syntace P6 31.6x 350mm (215gr)
    Seatclamp: KCNC black 34.9 (15gr)
    Bikecomp: Garmin Edge 705 Cadans/HR (GPS + cadanssensor + stemmount=150gr)
    Bottlecage: Cannondale carbon (21gr) with ti bolts
    Color: black
    Weight: 8480gr
    New pic's are coming
    Again some upgrades...
    - chain KMC X9L Silver
    - Schmolke Carbon seatpost (31.6 mm - 350 mm)
    - Tires: Vredestein Black Panther 2.0 or Vredestein Tiger Claw 2.0 or a mix of these two...
    Me and the Taurine somewhere in the woods in Flanders...
    During the marathon our club did organize last week...
    Kind regards,
    Steven
    GT Tequesta
    GT Zaskar Race
    C'dale Taurine
    C' dale Rush Carbon
    LA CHÈVRE
    Let me participate...
    When I got home after work today, this was waiting for me...
    More than somewhat.
    Are you gonna keep him? Might be rabid... Send it my way and I'll give it a proper send off.
    Reputation: Just J's Avatar
    Feb 2005
    Dan that looks cool, I can't wait for my bike to get here, I shoul dbe picking it up in about 2 weeks!
    Now that's a strange scalpel...
    FIRENZE rulez !!
    yes... very strange scalpel frame...
    to go lighter than me , do you eliminate rear shock ?
    ok saved 200 gr , DT and mounting supports
    Stewed Screwed & Tattooed
    Killer dude. Have fun with that thing!
    LA CHÈVRE
    What? It's not a Scalpel? :shock: Well, when I'll sit on it, it will look just like a Scalpel, like a Scalpel with a lot of air pressure in it's shock.
    Jan... I mean Cypress: I'm going to keep it for a while, try to tame the beast. Maybe I'll let it go in the wild eventually...
    Eliflap: even with no shock and a 500gr lighter frame, I don't think it's going to end up lighter than your scalpel.
    Ronald: don't worry, I'll have fun suffering in a few races with it, as soon as I receive a crankset for it.
    My new Taurine
    Here's mine new Taurine in nearly Team replica setup. Rides veeery fast
    But have a question - current 100mm/+5deg stem seems to be a little too short for me, so I was looking for 120mm/+5deg, but couldn't find any, only 120mm/-5deg. Does anybody know if this +5 really exists?
    Vlado
    Very nice. The C'dale stems can be flipped. Just get the 12005 and flip it up for +05 or down for -05.
    More than somewhat.
    How does one go about flipping the Si steerer/stem combo?
    What bar ends do you use? Like those stubby's
    Barends
    Quote Originally Posted by larsdanielsen
    Ergon GR2 carbon to reduce palm pain - those grips really works, but Ergon just announced lightweight version, available from end June, so probably will switch to this to shave some weight.
    Satisfied about the seatpost Steven? I heard they're very flexie?
    Reputation: Duncan1104's Avatar
    If you flip it you can get the ultra aerodynamic position
    More than somewhat.
    Quote Originally Posted by Duncan1104
    The fork would have to be locked out all of the time. THAT could end badly!
    LA CHÈVRE
    No no no, just build a front wheel with a Lefty hub and a BMX rim and you are good to go.
  67. #67
    What am I missing here? I have a couple older C'dales with headshocks and an older Scalpel with one of the original Lefty's. I just swap the stems all the time and flip them pos and neg whenever.
    Do we have a new definition of "stem" or are the new Lefty's different somehow?
  68. #68
    LA CHÈVRE
    Quote Originally Posted by Bones01
    Higher end Lefties now have a one piece stem/steerer tube. The stem is not bolted to the steerer but rather built as one single part. You slide the whole thing through the Lefty clamps, headset and head tube. The result is a slightly lighter combo and a stiffer one too. As an added bonus, it looks slick!
  69. #69
    More than somewhat.
    Edit: Dan wins.
  70. #70
    Hi'
    Please find some pictures of my Taurine Carbon Si2
    Link: http://rudemtb.dk/hotwheels.asp?fane...hotwheeltype=1
    Lars (Denmark)
  71. #71
    Jun 2005
    Taurine 3, same ace frame, lower end parts.
    Already upgraded shifters and f+r mechs to xtr, dura-ace cassette, X9-SL chain, P6 post, SLR carbonio saddle and KCNC bars.
    Cranks next then I'm onto a decent wheelset and its sorted, love this bike, they ride amazingly well.
  72. #72
    LA CHÈVRE
    Quote Originally Posted by wiiija
    Nice, those P6 posts are a popular choice on Taurines, that's my choice too as I figured out the only 31.6 post I had was too short. My build will start real soon, should have all the parts needed next week.
  73. #73
    Feb 2005
    That's a really nice bike, I'll be picking my Taurine 2 up in about a week or so!
  74. #74
    LA CHÈVRE
    Edit: Dan wins.
    If only it was that easy in XC races...
  75. #75
    if it were that easy it wouldnt be any fun...
  76. #76
    LA CHÈVRE
    True.
  77. #77
    Mar 2006
    Excellent bikes!! What's the cost of a Taurine frame?
    Jun 2005
    Cheers, yeh the Syntace P6 may not be the lightest post but their really well made with an excellent clamp design
  79. #79
    Jun 2005
    Thanks, you'llbe over the moon with the Taurine, great to ride
    Forgot to mention, the wheels are actually Fulcrum red metal 5's after the stock ones were shot for some reason the shope gave me these instead, surprisingly good for a cheap wheelset, excellent hubs, I had to de-sticker them though, the stickers are just too much!!
  80. #80
    Hi, from Portugal!
    I'm a double Cannondale owner. Started with a Prophet and more recently got a Taurine. Since I got the Taurine 4 months ago my life changed. It's absolutely an incredible bike, the power sensation is brutal, I can get a lot of fun and pleasure riding on it, abolutely amazing!
    It started as a Taurine 3, european model, and as you'll be able to see, it's almost a Team Replica. The feeling as so amazing that I kept loosing my head and wallet with upgrades.
    And here's me last weekend on a 24h solo race! Not really an official rider from Cannondale, but at events I like to look machting with the bike. The most funny thing is that at most races I'm in people always think I'm an official rider and they get scared and more respectfull.
    Next upgrades will be a CrankBrothers 4ti pedals, wich are currently on there way, and a new custom wheellset, probably with the new DTSwiss 190 ceramic hub on the rear, DTSwiss spokes and a XC717 rims.
  81. #81
    LA CHÈVRE
    Quote Originally Posted by arquitonto
    Hi, from Portugal!
    Where I race, you can only ride a team jersey if you are an actual member of that team, otherwise, the race marshalls can disqualify you. I need to ride undercover... or maybe I should register a Team Dan Gerous next year!
    Nice bike by the way.
  82. #82
    LA CHÈVRE
    Build is done: 19.75lbs (8960gr for you Euros) with heavyish Crossmax SLR (my pair weighs 1634gr without rear skewer), true UST tires and a Lefty Terralogic... Now I only need to fine tune the shifting and the Lefty. Pictures to come.
  83. #83
    LA CHÈVRE
    Here it is...
    I may need to switch to a seatpost with more layback and a negative rise stem...
  84. #84
    More than somewhat.
    Siiiiick!
    I guess I need to put my Taurine on a diet. My Team edition comes in at 21.3 lbs with Ergo2 Bar ends, XTR pedals, and Stans in the LUST Monorails.
  85. #85
    mad aussie
    Reputation: Flying Wombat's Avatar
    Very nice and light bike Dan. Without any stupid light parts to boot. Some Stans wheels and standard tires converted could easily run it under 19lb! It makes me sad that the small Taurine is just too short in the top tube and the medium too long for me. I can only hope they do a US made version with Super Six tech in a full run of their normal sizes.
    Kevin
  86. #86
    Good job!
    Very, very nice Dan!
    I'm sure it was worth the waiting...!
    Can you let uw know your experience with that KMC chain.
    I don't want to freighten you, but I heard they are not as strong as your Dura Ace/XTR chain and can break under heavy load
    I hope it won't happen to you. I so, I'll buy myself one to (bling bling + low weight: what can a biker want more )
    BTW, I have the same saddle on my Rush Carbon: great weight (120-125 gr) and acceptable comfort! Superb saddle.
    Also great to see German tires under the bike of a North-American (the continent) biker. Are Schwalbe tires easily available in Canada/USA. Secret: the best (racing) All-round tire for Marathon/24h races/All mountain is the German Continental Mountain King Protection (or the lighter but thin walled supersonic version) 2.2... If you have the chance to buy/test that tire, do so. Amazing grip, very easy rolling, dry, humid, mud, etc. It really can do everything. But it's a racing tire: a special soft rubber compound, so the knobs melt like ice before the sun...
  87. #87
    Here's mine. Pictures are from Nov. 2007. She has got a few upgrades since then... But still looks very blue-blackish :-D
  88. #88
    LA CHÈVRE
    I finally went for a ride yesterday, the bike is a real rocket! Light, stiff, it doesn't hesitate when you put the power down, it instantly shoots forward. The Lefty Terralogic is good match for the frame as it feels rock stiff when hammering, even out of the saddle.
    Mister T.: When I first saw the thread of the 2008 Racing Ralphs, I knew I'd like them and I am not disappointed so far. Fast but still with great driving and braking traction, cornering is also very good, they impressed me in loose fast corners. They are not as easy to find locally as say, Maxxis or Hutchinsons but they can be found here and there, pretty expensive though, I actually ordered mine from Germany and it came in much cheaper, around the same price as more North American tires locally. I didn't like older Continental tires but I have heard great things on their recent rubbers. Maybe next tires, I would probably go with the Race Kings though, maybe Mountain Kings when it's muddier. Maybe get those mounted on some Stan's wheels for races, I'm just not sure about the daily durability of Notubes rims and being a bit too close to the Race 7000 weight limit doesn't boost my confidence in them. The Crossmax, while maybe not the best wheels, are light enough but strong so they can be run everyday for a long time, just relube the freehub once in a while.
  89. #89
    Jun 2005
    Gorgeous Dan, very nice indeed
    I've changed the fox's to a set of Sids, the fox's ramp up way too much for me and I could never get near full travel, plus they had the dreaded knock which is just annoying.
    I really need a set of the Sid decals from the black sids I reckon, will match the bike perfectly then
  90. #90
    Dec 2005
    Kind regards,
    Steven
    what's the weight¿? there are beatiful
  91. #91
    Hi,
    Does anyone know exactly what model of eggbeater pedal the '08 taurine team replica comes with? Is it the 4ti, 2ti, ti, sl, c or mxr?
    Thanks,
    Nick
  92. #92
    Quote Originally Posted by njleach
    Hi,
    Thanks,
    Nick
    The answer from Cannondale USA is eggbeater c
    so you will save 127g by swapping them out and replacing with the 4ti...
  93. #93
    What method are you using to get a 1 1/8th fork in there? a reducing headset? if so which one?
  94. #94
    taTegOi
    Reputation: ribisl's Avatar
    Mar 2005
    Here is my Taurine. Size L, 9,6kg as shown on the pics.
    There are some possibilities to save weight: Really heavy Crossmax SL 1743g , 2,25 tires, bottle cages (I had some from tune but no chance to get the bottle out of them after a rough ride, and the CD carbon bottlecages always loose the bottle ), CD crank instead of the unpretty XTR, heavy xtr pedals, but I love their function and so on..........
    Lg Martin
    pics
  95. #95
    Smile
    My new baby!
    Sold the prophet mx 2 on ebay and decided to go with a hardtail. Love the speed!
  96. #96
    Update with final upgrades. Here's the result:
    Weight: 9,400 kg / 20,73 lbs
  97. #97
    How is that DT Swiss Skewer working out for you?
  98. #98
    And how about those wheels with the DT 240s hub - are they satisfying and durable enough for everyday riding?
    cheers
  99. #99
    Well, I can answer these both questions in once because these components were monted this week on the bike, so I don't have yet a feedback of how they work on it.
    The DT Swiss Skewer I found more practical to use, just roll clockwise to tight and the opposite to release.
    About the wheels, I came out from a DT Swiss stock mount and switched to these to get lighter and stiffer wheels. I still haven't got the time to really try it on the "jungle" but from the few miles I gave I found them more resistant and much more stiffer. This will be for everyday riding because I ride mostly every day, and I'm expecting to get from these wheels above all a much better compromise specially in cornering, wich was where I wasn´t feeling 100 % on the DT Swiss.
  100. #100
    Razor
    Reputation: RazorHolt's Avatar
    Cannondale Taurine
    Hi Guys,
    Can someone help me?????????
    I need a rear mech hanger for my Can Taurine frame but my LB does not seem to want to help me. Can you tell me the mech type / number i require for this frame. Also where i can get hold of a BB convertor to enable me to run an XTR crank?
    Cheers, Razor.
