Page 26 of 42 FirstFirst ... 16 22 23 24 25 26 27 28 29 30 36 ... LastLast
Results 626 to 650 of 1033
  1. #626
    YB1
    YB1 is offline
    I just got a 2011 Scalpel. Has anyone tried anything different with rear brake line routing? I"m thinking straight up the "seat stay" and along the top tube like the old Scalpel?
    Emory Kalahari Kruiser
  2. #627
    I have been thinking about the same thing.. I would prefer this as well If only for esthetic reasons.
    Cable routing along the Shock needs to be different than before. The mounting point is now an integral part of the Frame and doesn't leave much room to feed a cable trough.
    Does anyone know the reason they changed this?
  3. #628
    Quote Originally Posted by dacade View Post
    Hi Guys,
    have been hanging around for a while..
    Got mine not to long ago, have driven a few hundred kilometers by now.
    I waited over 4 months to get it but haven't regretted one day.
    Greets from Germany,
    D
    Hi!
    Is your scalpel an XL size? How tall are you? I am having some troubles to define myself between L and XL since I am 190cm (6'3") tall and from BB to top of the saddle I have 81cm (32 inches).
    Quote Originally Posted by Not-4-You View Post
    Hi!
    HI
    Yes it's an XL frame, I'm 193cm tall and BB-seat for me is 78. So I have shortish legs but long upper torso.
    I like the XL very much, although its quite long but woudn't want to have it any other way.
    Hope that helps.. In the end maybe you need to try some bikes out in the Shop. I drove some different race bikes, some were L and some XL, thats how I found out.. (my old hardtail was a size smaller, now i cant believe i waited this long to buy an new bigger bike!)
    greetz
    Dacade
  5. #630
    Nov 2006
    I would go for the XL. I am 6'2" and that is what I had. It did not seem too large by any means.
  6. #631
    Thank you for the help. The problem is that so far I couldn't find any store with L and XL scalpel to test. :/
    Still, I believe that I cannot have an L, I will need a XL. Unfortunately the bike loses a bit a charm and most likely a bit heavier than smaller ones.
    Anyway, XL will be. The issue now is if I need a Scalpel... maybe the Flash is comfortable enough with the SAVE system
  7. #632
    Reputation: wannabeRacer's Avatar
    you thought about 29er Flash or Scalper?
  8. #633
    No, 29er is not an option for me. I am a 26 guy and I want a nimble, nervous racing bike
  9. #634
    bao
    bao is offline
    has anybody used a project 321 steering adapter to use 1 1/8 stem? if so, any durability issues/problems with the set-up?
  10. #635
    Grip it and rip it.
    Reputation: Damitletsride!'s Avatar
    The new lefty's look sick.
    "Pain is inevitable, suffering is optional"
    michaelmblog.wordpress.com
  11. #636
    YB1
    YB1 is offline
    650b it and you'll still have a race bike. I dunno about nervous but it for sure won't ride like a 29'er.
  12. #637
    Thoughts on parts
    I know that this question is subject to opinion, but what make&model FDs are best on the Scalpel? Any thoughts? Any problems with the SRAM XX direct mounts?
    Any thoughts as to which headsets?
  13. #638
    endurance and race rig
    2008 carbon scalpel frame size XL
    2011 XLR Lefty
    2010 mavic slr wheels
    2010 hollow gram cranks
    Formula R1 brakes
    3x9 setup
    22.5 lbs race
    23.5 lbs endurance (saddle, rear cassette, mountain feedbag and saddle pack)
    Attached Thumbnails Attached Thumbnails Post your Scalpel!!!!-blackberry-109.jpg
  14. #639
    locked - time out
    My 2012 C-dale Scalpel Ultimate (26in) Team Cannondale Factory Racing .....
    Just picked it (stock) up today from Freshbikes, Arlington VA.
    Surprisingly, the bike came in less than a month upon ordering.
    Weight w/ EB11 pedals: 18.86 lbs
  15. #640
    A little of everything
    Reputation: Anders's Avatar
    2009 Scalpel 100 "Team Replica"
    The frame arrived a week ago and just finished the build after receiving a new BB30 spindle. It's a used 2009 Team Replica in large that weigh 2178g including seatpost clamp. I carried over all the parts from my Rush and the weight is now 9.92kg. It's not WW light mainly due to the Lefty Terralogic (1511g), but I have a few things comming and planned to get the weight down a bit.
    Using long steel pedal spindles in the winter --> short Ward Industries ti spindles -40g
    Hope 180/160 floating rotor --> Ashima aiRotor 160/140 -90g
    Rocket Ron/Furious Fred 2.25" --> Rocket Ron 2.1"/Furios Fred 2.0" -130g
    Shimano XTR FD --> Campagnolo Super Record FD -50g
    That should bring it down to 9.61kg for next season.
    A set of Formula R1 brakes and a Lefty SL could shave another 500g, but let's see what happens.
    Fisrt ride was today at a local race this saturday. It was just a completely different experience than the Rush. On the positive side is a much more race oriented feel, sharper/faster cornering, more agile in tight stuff and it actually feels like a hardtail with the shock locked.The most negative observation is that it just doesn't have the flow on the single tracks that the Rush had so you need to put power down constantly to keep it going.
    I should add that the Rush was a size XL that I rode with a 90mm +5 degree stem, whereas the Scalpel is a large with a 110mm -5 degree stem.
    Newly build
    After the first muddy ride
  16. #641
    Reputation: bikesinmud's Avatar
    Dec 2005
    Anyone with a '11 or '12 scalpel able to stuff a 2.25 nobby nic in the rear?
  17. #642
    Quote Originally Posted by bikesinmud View Post
    No problem (Racing Ralph 2.25 and Nobby Nic 2.25) but in muddy conditions, be careful to protect the flexstays with clearcoat (3M or other)
  18. #643
    Dec 2005
    Quote Originally Posted by Archicoolaurel View Post
    thanks, my dealer doesn't have any in stock and I've got 2.1's Rocket Rons on the bike which are pretty skinny.
  19. #644
    With NobbyNic/Racing Ralph 26x2.25
  20. #645
    Dec 2005
    hey, if you got time post some pics of tire clearance on both tires NN and RR at the chain stay and seat stay. I'm sure there's not me who's interested. Thanks!
  21. #646
    Dec 2011
    I ve my new scalpel 2 2011. I bought ita week ago and this weekend went for a wonderful ride with 20% hills and muddy slippery singletracks. This bike is amazing!!!!
  22. #647
    '06 Scalpel with Headshok
    I've always wanted one of these! Finally picked up a nice frame with Headshok and an RP2 on the back. Only about 300km on it so far and I love it.
    I had the wheels and tires already built and ready by the time the frame arrived so I threw them on:
    Built it up with a nice '12 XX group:
    And here are the specs:
    Frame - '06 Cannondale Scalpel, Optimo Tubing
    Front Suspension - '06 Headshock DLR80
    Rear Shock - Fox Float RP2
    Rim Front - Stan's Crest
    Rim Rear - Stan's Crest
    Hub - Front - DT Swiss 240
    Hub - Rear - DT Swiss 240
    Skewers - DT Swiss RWS Titanium
    Tire Front - Continental Race King 2.2
    Tire Rear - Continental Race King 2.2
    Bottom Bracket - '12 Truvativ GXP BB
    Cranks - '12 Truvativ XX 39-26
    Rear Casette - '12 SRAM XG-1099 11-36
    Chain - '12 SRAM PowerChain 1091R
    Derailleur Front - '12 SRAM XX 10 Speed
    Derailleur Rear - '12 SRAM XX 10 Speed, Medium Cage
    Shifters Front - '12 SRAM XX 10 Speed
    Shifters Rear - '12 SRAM XX 10 Speed
    Brakes Front - '12 SRAM XX
    Brakes Rear - '12 SRAM XX
    Pedals - '12 CrankBros 11
    Handlebar - FSA K-Force Flat
    Grips - Extralite
    Barends - Extralite Cyberends
    Stem - Cannondale 110mm @ 5 Degree Rise
    Saddle - Specialized Henge Pro
    Seatpost - Thomson Masterpiece Setback 330mm length
    Weight - 9.9kg
    I hope you guys like it. One possibly interesting note, I changed the 90mm, 5 degree stem to a 110mm, 5 degree stem. This raised the handlebar height about 15mm.
  23. #648
    Reputation: BoostN7's Avatar
    Dec 2010
    Quote Originally Posted by archicoolaurel View Post
    with nobbynic/racing ralph 26x2.25
    jiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiizzzzzzzzzzzzzzzzzzzz
    and no, I am not missing the other half of my fork....
  24. #649
    Reputation: Just J's Avatar
    Feb 2005
    Quote Originally Posted by Taurine1 View Post
    That looks amazing!
    Tell me please, does it have dropper post routing?...
  25. #650
    I just went from 26" to 29", hardtail to f/s, titanium to carbon frame, 3x9 to 2x10, tubes to tubeless... couldn't be happier.
  1. Scalpel or Prophet?
    By subzero in forum Cannondale
    Last Post: 10-29-2004, 12:29 PM
  2. '05 Scalpel 2000 or '04 Scalpel 3000???
    By Caleb in forum Cannondale
    Last Post: 10-28-2004, 01:04 AM
  3. Reply withOUT quotes
    By Vecsus in forum General Discussion
    Last Post: 08-25-2004, 01:49 PM
  4. The post I hoped I would never post
    By jayz in forum Jamis
    Last Post: 08-04-2004, 07:43 PM
  5. 5 Spot seat post diameter !
    By Steve5S in forum Turner
    Last Post: 06-18-2004, 05:48 PM
