Page 16 of 18 FirstFirst ... 6 12 13 14 15 16 17 18 LastLast
Results 376 to 400 of 432
  1. #376
    Reputation: BoostN7's Avatar
    Dec 2010
    Nice job Proxy, I really really like that bike!
    and no, I am not missing the other half of my fork....
  2. #377
    Dec 2010
    Quote Originally Posted by Devastazione View Post
    Amazing bike man.
    I'm turning 40 in june and I'm looking at the Scalpel Ultimate as a present to myself. There's only two things holding me up : my hearth is still with my now gone 2012 Epic/Brain thing and possibly the idea of buying it back and june is already that time of the year to see C'dale 2014's models.....decisions,decisions,decisions.
    Wait for the 2014 models, that's what I'm doing
    Quote Originally Posted by kirkB View Post
    Just got my first Cannondale this weekend. This thing is a rocket for sure.
    Walked in to buy some Enve wheels - walked out with a new bike. Whoops.
    Looks like you are in the same area as me jbbikerider. I had the shop swap out for black spokes and logos on the wheels, otherwise looks to be about the same bike.
    Attachment 773507Attachment 773508
    Quote Originally Posted by Cruzing_fool View Post
    She's pretty basic but working on it
    Attachment 775580
    Attachment 775579
    You brought some Enve wheels didn't you? I'd say that was a success. Nice of the bike shop to throw in those accessories
  3. #378
    Jul 2013
    Post a pic of your Cannondale  29er-20130704_170505.jpg Post a pic of your Cannondale  29er-20130704_173138.jpg
    Our two lefties at Union Falls, NY in the high peaks region of the Adirondacks. 2010 flash 2 aluminum 26 and 2013 flash 3 carbon 29. New to this site. Lots of good info!
    Mike
  4. #379
    At Alpe d'Huez (France)
  5. #380
  6. #381
    Reputation: nathanbal's Avatar
    awesome!
  7. #382
    Reputation: StumpyElite2010's Avatar
    Awe inspiring... Need to plan my next vacation around that area
    BTW, why 2 fingers on the brakes ?
    S.C. TB2
    Pivot Mach 5.7 27.5
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
  8. #383
    Reputation: mnyquist's Avatar
    Post a pic of your Cannondale  29er-imageuploadedbytapatalk1376853746.811500.jpg
    Few upgrades to my Scalpel
    Hollowgram crank
    Chris King ceramic PF30
    Enve XC/DT240 hubs
    Easton EC90 Bar/seatpost
    ESI chunky grips
    Arundel side loader
    Formula R1 racing brakes
    Ashima 160mm rotors
    Selle Italia SLR kit Carbonio flow
    SRAM XX cassette
    Egg beater 2Ti with Ti spindles
    Snakeskin Ron/Ralph
  9. #384
    Jul 2013
    Flash 29er
  10. #385
    Quote Originally Posted by StumpyElite2010 View Post
    Because right after the jump there was a corner.
    Btw, mostly of the time when I'm riding technical tracks, I'm riding with one or two fingers on the brakes. Always a quick response!
  11. #386
    May 2013
    I guess my bike classifies as a 29er too. Just posted in the trail thread.
    Noobish
    2013 Cannondale Trail 29er 1
    1990ish Specialized Hardrock
  12. #387
    Cannondale F29 Carbon 3 Custom with mods
    Here is my new Cannondale F29 C3. I recently sold my 2010 26 Flash that i had posted on the "Post your Flash" thread. Weighs in at 8.9kg. Flys!!!
    All original parts are boxed and stored for resale.
    New parts include:
    1 x 10 Shimano XTR drive train
    Shimano XTR race brakes
    Cannondale SI crank
    EggBeater 11Ti Pedals
    CruveCycling wheel set
    A tip to other F29 owners. Note how i have routed the cabling for the rear mech. It is tied to the brake hose and runs down the drive side seat stay and maintains full outer casing. I recommend this routing for increased shifting performance in muddy conditions. The straighter cable line and full length outer generally improve shifting in any condition. And improve the longevity of your cables. IMO
    Attached Thumbnails Attached Thumbnails Post a pic of your Cannondale  29er-cdalef29outside.jpg
  13. #388
    Sep 2013
    Hey Brucesleeve,
    So glad I found your post 'cause what you've done is exactly what I'm trying to build up. I have the same spider for a RaceFace narrow wide 32 tooth chain ring for 1x10 setup. What chainring bolts did you use for your bike and have you modified anything else in the conversion? Also, what shifter are you using?
    I love your idea about the rear cable route. Am going to take that on too. Always bewildered me somewhat that Flashes have exposed cables on the down tube to get covered in dust and crud. Seems counter intuitive to me given its something one would want to keep clean and reduce friction on.
    Cheers,
    Abes
  14. #389
    Quote Originally Posted by Flash Abes 29 View Post
    Hey Brucesleeve,
    Cheers,
    Abes
    Hey Abes,
    Yeah, having been a bike mechanic for many years I was baffled that Cannondale hadn't evolved its cable management on the flash since my first 26 flash in 2010. Every race I did on that I had to recable it. This works a lot better.
    I'm using the 3x10 hollow gram spider on the middle setting. With single speed c/ring bolts.
    I'm using an xtr 10sp shifter that is directly mounted to the brake.
    The chain guide is the e-thirteen e-type direct mount with an e-thirteen 34t ring. Cassette is 11-36 so I get quite a wide range and no chain rub. All of this set up using the xtr clutch type rear mech is perfect for me.
    One other thing ill mention is when I removed the original SRAM crank to install the Cannondale crank, I found that the new bb shells have a machined in bearing race that eliminates the need for circlips. It however also had circlips installed. These need to be removed to get the spacing on your Cannondale crank to work properly. If you leave them in you will overload your bearings, as you will see the wavy washer press flat as you are tightening.
    Good luck, any other questions please ask. And share pics when you're done.
  15. #390
    Sep 2013
    Brucesleeve,
    Cheers for the quick reply and extra advice. I've got an XTR ispec shifter coming but will be going with an XT shadow plus rear derailleur. Thanks for the detail about the chain ring setting. I'm going to do mine sans chain guide as the word on the narrow wide RaceFace chainring is that they don't drop, especially with a clutch mech. The reality is I'll come off the bike before the chain does if anything gets hairy enough to threaten displacing it!
    Will be sure to get pics up as soon as I can get the bike built. Probably about a month from now but I live in hope it'll get done sooner.
    Cheers again.
  16. #391
    all about the all about
    Reputation: Om Flyer's Avatar
    Post deleted
    .. If I see this bike on display with those GT bars, I am bringing my hacksaw!!
  17. #392
    Reputation: MarinCRO's Avatar
    Jul 2013
    Trigger 1 29er near the local winyards.
  18. #393
    Sep 2013
    day 1
    Just got my Trigger last Sunday so no action pics yet. Here's a pic of me taking it home from the LBS.
  19. #394
    Reputation: xluossa's Avatar
    Quote Originally Posted by hellari View Post
    Nice pic hellari!
    for urayamu1! More like a car pic
  20. #395
    Reputation: HSracer's Avatar
    Jun 2013
    2013 Carbon 1 size medium. Picked it up yesterday. Flatted on the first ride, then spent about 4 hours trying to convert it to tubeless , but I finally got it . Tubeless with pedals its around 21.5 lbs. So stoked! Rides like a dream
  21. #396
    Jan 2014
    Quote Originally Posted by tommieboy View Post
    That could be the right weight for a Large. A medium = 9,765 kg
    Hi guys. Just got large 2014 f29c2 put Stans crest tubeless wheel set on it with racing Ralph's 9.7kg, without pedals
  22. #397
    Reputation: mercyNside's Avatar
    Jan 2014
  23. #398
    Reputation: fishboy316's Avatar
    Jan 2014
    Brand spankin 2013 cannondale f29 1 AlloyPost a pic of your Cannondale  29er-0202141554.jpgPost a pic of your Cannondale  29er-0202141522.jpgPost a pic of your Cannondale  29er-img-20140131-00059.jpg
  24. #399
    Jul 2013
    Couple of new photos from today, Trigger 1 29er.
  25. #400
    Reputation: dna_05's Avatar
    Dec 2011
    My Scalpel 29er 3 coming home from the LBS
    And here after the first ride, with some cheap-ass pedals waiting for my new ones to come in the mail.
    Full stock for now.
