Results 1 to 25 of 25
    Reputation: kneejerk's Avatar
    Dec 2008
    Picked up a '11 RZ120 four
    deleted
    Attached Thumbnails Attached Thumbnails Picked up a '11 RZ120 four-untitled-1.jpg
    Seriously what a lucky kid you have there
    I agree 33lbs(!) is quite heavy for an XC / endurance bike, but it's a good training for his legs!
    Mr. Yeco
    Jan 2011
    Hi kneejerk
    Hello from Mexico, I have the same model but the last year 2010, my bike has a stickers that said made in usa, I would like to know if the build process change from one year or another, and I'm agree with you about the rims and the drivetrain is too heavy, I would like to know if is convenient improve the drive train and rims. And the RST works well when you adjust with low rebound and less air pressure,
    I'm sorry for my english.
    Reputation: gsxr1600's Avatar
    Nov 2008
    Was there a reason you put the rear shock on the 120 like that.
    May 2010
    Quote Originally Posted by gsxr1600
    I think its like that to be able to access the water bottle cage. I also think it comes like that from the factory.
    Mr. Yeco
    Jan 2011
    Hi Dkestar
    I have the same size, and the rear shock is in a normal position, but in the manual said that must be in the other position.
    regards
    Nov 2008
    Here is mine, this is how mine was on.
    Attached Thumbnails Attached Thumbnails Picked up a '11 RZ120 four-bbg-012.jpg
    Nov 2008
    I see now, the medium and bigger frames mount it like mine, and the small are mounted the other way.
    Mr. Yeco
    Jan 2011
    Hi gsxr1600, what happend if the small frame has the shock like yours bike, could it damage the frame? Because my bike has the shock like yours and is a small size
    Dec 2008
    Quote Originally Posted by Yeco
    Yes, if the size small has the shock turned around like my Rize (large) the barrel may (or will) pinch against the top tube during travel. I did turn the adjuster knobs to the top to make it a little easier to get to a water bottle w/o bumping them, although this made the shock fiddling a little more difficult (maybe).
    Dec 2008
    You can always make the bike better with lighter or better parts. It becomes a matter of how much money you want to spend. At the price of this complete bike it is on par with some frame sets available. I think the performance is good.
    Dec 2008
    Just noticed from your picture that your chain may be too short!....... it looks to be pulling the rear derailleur to its maximum without the suspension being compressed. Most rear suspension systems will pull the chain when it travels, which will render the rear derailleur to its maximum and potentially bend or break violently.
    Reputation: alex_k's Avatar
    Quote Originally Posted by kneejerk
    the chain looks fine
    Mr. Yeco
    Jan 2011
    Hi Kneejerk, please see the picture, I dont know if I must change the side of the shock.
    Thank you for your reply
    Attached Thumbnails Attached Thumbnails Picked up a '11 RZ120 four-imag0054.jpg
    Nov 2008
    Mount your shock the other way if your frame is a small.
    Nov 2008
    I shorten the chain because i have one ring up front and was gonna run two bashguards and didn't want to drop the chain, but the inner guard rubs the frame, so i put the derailleur back on for now to keep the chain from coming off, but the chain is fine like that.
    Mr. Yeco
    Jan 2011
    What comments do you have about the rize?
    Regards
    Mr. Yeco
    Jan 2011
    Regards
    Dec 2008
    deleted
    Dec 2008
    Yes, size small should have the shock turned around the other way.
    Dec 2008
    Update for this: Kid is now 14yo and just over 110lbs. I've changed out the suspension to a Fox 140 up front and a Rock Shox out back, the 140 fork is only fractionally taller than the original RST120 (actually the RST120 can easily be converted to 140 internally), the Fox fork switch has cut almost a 1/2lb. off bike weight. kid is about 5'4" now and the bike is fitting good.
    Dec 2008
    pivot bearing damage
    Well, discovered a pivot bearing come apart on the top of the seat stay on 100lb. rider (kids) RZ120 yesterday. Remember that "kink" in the rear suspension I discovered at my initial assembly of the bike!... kinda makes me suspicious! Looks like I will be looking for some new bearings and some new hardware very very soon... bike out of commission for now.
    Picked up a '11 RZ120 four-4_25_14-002.jpgPicked up a '11 RZ120 four-4_25_14-003.jpg
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    This is a 3 yr old bike, right? That is exceptional sus bearing longevity.
    Mine did not last a year.
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    Dec 2008
    I've got a 2008 140 with no such problems, yet... but, I am ordering some spare bearings... just incase the day comes sooner rather than later..
    Quote Originally Posted by Stumpjumpy View Post
    Dec 2008
    Well, I ordered replacement hardware kits and Enduro bearings to fix this problem. Strangely the Enduro bearings are a few thousandths smaller in the outer diameter which made them slide into place rather than press fit. So, I installed them with medium strength loctite in hopes that would hold them in (time will tell). I used the Enduro bearings because they are of a higher grade with more ball bearings inside. No more "kink" noticed after installing the new bearings. Hoping this holds it for a while! I'll take it apart again as a regular check to see how it's going. I believe Cdale recommends checking the bearings every 25hrs. of use. Something I need to consider in the future and something my 2008 is definitely "due" for!
