Results 1 to 5 of 5
Thread: Parts for Frame
    May 2005
    Parts for Frame
    If I bought just a Cannondale Rush or Rize frame, what parts would I be able to transfer over to it from my 2005 prophet? Thanks.
    Reputation: amillmtb's Avatar
    Jun 2005
    Most likley all of them, the only thing you would run into problems is the eye to eye legth on the rear shock. It is similar on the rush but I dont think it is on the Rize.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Normally, a new frameset comes with the appropriate shock. The Lefty on the Prophet would be a bit too tall for the Rush but would be fine on the Rize.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Reputation: Duncan1104's Avatar
    Actually the stroke and i2i on the rize are the same as the stroke and i2i on the prophet according to the cannondale tech sheet. Plus the rize frame already has a rear shock most likely.
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    The Rize also uses a TOP pull clamp on style front derailleur instead of a e-type like on the Prophet.
    The Rize also has a larger size diameter seatpost if I'm not mistaken.
    I'm also playing with the thought of getting a Rize frame, but I think i'll just wait until c-dale has one in a polished aluminum finish
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
