Results 1 to 3 of 3
Thread: P.S.I. question
    P.S.I. question
    I know this is different for everyone, but what is a ballpark figure for P.S.I. on the 2008 fox f-120 Rl shock and for the fox rp-23 shock?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    What bike? Rear shock pressure will vary a lot depending of the bike's suspension layout. I put 55psi in the RP23 of my Scalpel, I'm 155lbs. But a Rize or a Rush would need much higher pressures... No clue about the fork though, if it has two legs, I'm not touching it.
    But, starting with a 25% sag is probably a better way to start than by going with the values others will give.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    It's a 2008 Rush SL. I figured I'm going to have to go by sag. The fork does have two legs.
