Results 1 to 8 of 8
    Hawkish on Choads
    Reputation: jhandy's Avatar
    Oct 2007
    Over reset the bearings on my Lefty
    I was doing a bearing reset on my Lefty Carbon Fox RLC 130. The manual says the extended measurement should be between 740 and 750 mm.After pounding on it for a while I got it to about 725 mm. It went from about 725 mm to 765 mm with a good whack on it and now I can see the bearings coming out from under the carbon part.
    Did I really screw it up? Is this something I can fix myself?
    I have searched and can't find what to do if you get over zealous on a bearing reset.
    Any help will be greatly appreciated, I am going to Moab tomorrow.
    I posted this in the Lefty bearing reset thread but thought it might get noticed quicker as a new thread.
    Attached Thumbnails Attached Thumbnails Over reset the bearings on my Lefty-img_0216.jpg
    When you say "pounding on it for a while" do you mean pulling on the lower by holding on to the axle stut.. or did you actually somehow use a hammer? I know this isn't directly giving you an answer on how to fix it but might clarify how it happened.
    Hawkish on Choads
    Oct 2007
    I was just holding the handlebars with one hand and throwing the wheel down with the other. No hammer involved.
    Feb 2005
    Suckful timing.
    Tear down and rebuild. No other way to get that tooth paste back in the tube, sorry....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Hawkish on Choads
    Oct 2007
    Well I went out and bought a Prophet off craigslist last night. First ride on it today on Slickrock.
    I will tear into the ol' Lefty when I get home I guess.
    Jun 2010
    I wonder where did you see that extended measurement should be between 740 and 750 mm ? It is Max 130 and in the manual it is clearly stated 720-730mm.
    Quote Originally Posted by Vasiliyg View Post
    He needs some glasses or he was looking at the 140 RLC which I think they only made for 1 yr.
    Lead by my Lefty............... right down the trail, no brakes.
    In a desperate move you could have pulled the Lefty and steer tube off the Prophet and put it on your current setup. I know that works because that is what I did. Prophet to Rize 140 with the same Lefty.
  1. When to reset Lefty bearings?
    By adambikes in forum Cannondale
    Last Post: 11-22-2011, 09:07 AM
  2. Lefty Max XLR bearing reset HELP!!!
    By packfill in forum Cannondale
    Last Post: 05-26-2011, 08:52 AM
  3. reset bearings on lefty xlr 100mm
    By campa85 in forum Cannondale
    Last Post: 03-03-2011, 10:54 AM
  4. lefty reset too often
    By adamantane in forum Cannondale
    Last Post: 02-13-2009, 11:05 AM
  5. Bearings Always Need to be Reset...Help!
    By RideFaster in forum Cannondale
    Last Post: 08-13-2007, 05:36 PM
