Results 1 to 3 of 3
    Oil wight for Fatty Ultra 70
    Hello, I changed the coil in the Fatty 70 to the hardest one. But now I wonder which oil wight is the best to fit to this coin. 7.5 wt or even 10wt ?
    I weight about 82kg/180 pounds.
    Thank you for your recommendation.
    Volker
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    I'd go for the 10 weight.
    I used 7.5 in my old Delta V that only has a lock out.
    If yours has a 5 click rebound adjuster I'd definitely use the 10 ... On the other hand I like my forks fairly firm so maybe you try both.
    If 10 is too harsh for your liking you can always go down to 7.5
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Thank you. Maybe I go for a lefty. But first I`m going to change the oil.
    Volker
