Page 11 of 11 FirstFirst ... 7891011
Results 1,001 to 1,057 of 1057
  1. #1001
    Sep 2014
    Hey Lefty people! I've been a Lefty mechanic for years and I have a problem that has me baffled. Supermax pbr 2.0 140 (alum) - would not hold air from the factory (2016 purchase) but decided to simply do a full service on it before it went out the door 6 months ago. It has come back for THREE rebuilds. Same issue each time. Seems to hold air, we test ride it hard, seems fine. Customer pounds it and it goes flat. Air pressure holds, but fork goes thru stroke. Then it slowly rises back to full extension and seems to work for a bit. The lower the pressure (ie, functional range <100 psi) the faster it fails. if I put 175psi in, it holds and maintains through the rough stuff too. I have replaced the 2Spring TWICE, lower and upper (and inner) air seals TWICE. Used slick honey on the orings, and a small bit of Float Fluid (I have used it successfully on leftys for years). Well, its back again. I talked to Cannondale tech and I got nowhere. Seems like either the lower seal is failing or the plunger seal is failing, then allowing air to leak back from neg to pos chamber. But 2 defective 2Springs randomly??? At this point, I'm wondering if I don't have a defect in the lower leg? (cleaned internals well with alchohol) ANY ideas and thoughts are welcome. I'm not the smartest guy here for sure. Thanks.
  2. #1002
    Oct 2015
    My money would be on scratching on the inner surface of the lower leg allowing air to transfer between the chambers.
  3. #1003
    Sep 2014
    That's where I'm thinking but I have a new thought. I now know why it holds at high pressure (170psi) ... the customer can't bottom it out. I believe the air transfer (non desireable) is happening at full compression (fully bottomed). I can ride it all day long without issue at 65psi but the customer rides considerabley harder and weighs a lot more - thus when I set up the suspension properly for him, he does bottom once in a while and that's when it's happening. Does that clue help?
  4. #1004
    Hi all.
    Tried to search but so many pages to go through on Tapatalk.
    I have a new 2018 scalpel si. I wish to convert the xlr lockout to a pbr setup.
    I know on my hybrid it was a complete damper change.
    But I read somewhere that on the 2.0 itís just a top cap change to do the conversion?
    Is that true? And what is the right part number?
  5. #1005
    HI Boosted GP, you just need the KH188/ without any other hassle: the modification can be made externally indeed.
  6. #1006
    Reputation: Chrizzzz's Avatar
    Feb 2016
    easy:
    For sale:
    - Cannondale 2x Spider XX 120/80
  7. #1007
  8. #1008
    Reputation: akacoke's Avatar
    i got this lefty max with pbr internals for my fattie. 2 questions now.
    1. there is subtle thud noise at the end of compression when the fork is all the way back up when the bike is on the ground im pressing down on the fork. is this normal?
    2. what sort of air pump is gonna work on these? seems like the air valve is more ressed in the fitting i cant get a pressure reading when im pumping or when the pump is screwed all the way in. and whats kinda pressure i should be running ? is there a pressure chart?
    17 Lynskey Fatskey
    07 Kona Stab
    14 Specialized Fatboy
    04 Santa Cruz V10
    My Parts for sale link
  9. #1009
    Is there a difference in dimensions between an kh149 and kh188 pbr knob? I know the kh188 fits the lefty 2. But will a kh149?
  10. #1010
    Reputation: rupps5's Avatar
    Quote Originally Posted by Boosted GP View Post
    Both fit the same. The 149 is the old knob style and the 188 is the new knob Style. Think the 188th is available through Cannondale and the 149 is out of stock.
  11. #1011
    Rides all the bikes!
    Reputation: Sidewalk's Avatar
    May 2015
    Is it basically that simple to do the reverse? A friend and I were planning on swapping Lefty's when we send ours out for service as he has the remote and I don't. But I'd like to keep this in mind as an option.
  12. #1012
    I will let you know, but it should be an easy swap. There is a video for it. Got the k h188 kit today, will probably do the swap this weekend and let you know
  13. #1013
    2 questions....
    a) I've read *most* of this thread - at least Mendon's posts - Which of the 1.0/Booted leftys is considered the "best"...in terms of longevity, serviceability, reliability, function? I say 1.0/Booted as it sounds like the Hybrid and newer non-booted ones are certainly not Mendon's favorite
    b) What patent does Cannondale still own that is preventing someone else from designing their own lefty? I mean you see forks and shocks by many manufacturers and they are essentially the same. A lefty is essentially a Strut that you'd find on a car, so I'm wondering what is preventing someone else from making their own version?
  14. #1014
    Pretty easy swap. The only slightly difficult thing was getting the little C clip out. Otherwise it was a pretty simple and fast conversion
  15. #1015
    Your dog looks satisfied with the job!
  16. #1016
    May 2015
    I might be in the market for a used lockout soon
  17. #1017
    Apr 2017
    Hi, just wondered if someone can clear up for me which hubs will work on my Lefty Max 140mm (06/07). It all seems pretty confusing with the Lefty 60, 50, and who knows what else hubs that are out there. Any help would be much appreciated. And I'm 6"4", 220lbs, so I'm looking for at least a 32 spoke version. Thanks.
  18. #1018
    Aug 2015
    Hi all,
    Inner leg of my 2K13 Lefty seems to be completley died. How ? Many scratches, inner leg looks more a square than a circle and now i can see oil leak.... I made all services in time, very disapointed.
    I haven't been here from a while, Is there any procedure to remove the leg, I would try to reanodize it.
    I use to send my forks to push industries for rebuilds (or rebuild my forks myself) and modifications..well, push doesn't work on lefty forks. So who or where can i send my lefty for modifications? specifically looking to try and get 110mm travel, or upgrade some of the internals to make it a bit more plush.
    I saw some vids and instructions on rebuilding the Lefty fork, seems easy enough to do it myself, but..i can appreciate a great mechanic that can get my fork to the next level. Any and all info will be greatly appreciated
    Jesse
  20. #1020
    Quote Originally Posted by jesse101 View Post
    Jesse
    Mendon Cyclesmith. No other
  21. #1021
    Mar 2018
    Hello. Need a little help identifying an issue with my lefty 110sl carbon. I noticed on my last ride that I felt like I was going to fall forward on descents. I stopped to check it out and realized the shock is slowly leaking down while locked out or unlocked. The shock does not have an air leak as I checked the pressure before and after the ride. I do not see any oil leaks of any kind. I made a quick video to show the issue. Just looking to see if this is a quick adjustment fix or will it need to go in for repair. Any help would be much appreciated. Here is the video.
    https://youtu.be/QFvNdWVOPCg
  22. #1022
    Quote Originally Posted by SurfnShoot View Post
    More than likely the o-ring found around the lockout piston (internal). They can lose their round profile and end up allowing oil to seep between it and the ID of the oil cylinder. If it's not seen service in awhile or never, then it's time...
  23. #1023
    Jun 2017
    Hey all,
    Curious if anyone else experiences this with their Lefty 2.0 PBR 130mm 27.5. I own the 2016 Habit SE. After only couple of rides I very quickly lose maximum travel. For example, after this weekend of riding, I let all the air out of the Lefty and sank to about 20mm above the recommended 35mm gap from the bottom required of the bearing reset instructions. Doing a reset seems to restore full travel but it seems to occur more rapidly then the 25hr recommendation for a bearing reset. Is this common to occur this quickly? I often ride technical rocky trails here in Boulder CO so maybe they're responsible for more chatter and thus throwing the bearings out of alignment more quickly than the norm. I am currently having it go through a full service but I am wondering if this is a potential sign of something more serious.
    Feb 2016
    Thats quite normal. So you dont use the full travel all the time.
    Maybe use 5psi less pressure.
    I have to reset maybe every week and i do it before every race to have full performance.
    But i run maybe 5-10psi more in XC conditions.
    For sale:
  25. #1025
    Dec 2008
    Any update on this? I'm looking at doing the same thing.
  26. #1026
    Mar 2018
    Hello all,
    I have a 2016 Cannondale F-Si Carbon with a Lefty 2.0 100mm PBR. I used the bike extensively in 2016 without a single performance issue. In 2017, life got in the way and it was maybe ridden 20 hours. It spent the rest of the time hanging in my garage. It was hung "wheels down" by the handlebars and seat. I've ridden it a couple of times this year and noticed that the rebound damping doesn't seem to work. The PBR knob rotates and the button works and locks the fork out but there is no noticeable difference in rebound rate from - to +.
    I do tend to ride the fork in climb-mode the vast majority of the time. I've read a few threads that suggest this can harm the shock but no explanation of how/why.
    This fork has never been serviced and I've been planning a PBR-to-XLR conversion which I'm going to do now. I also need to add the 2Spring kit. I'm very comfortable with the maintenance on these lefty's and am going to be tackling this myself.
    A couple of questions:
    1) Theories as to why the rebound isn't working?
    2) Where to buy a damper seal kit? I've located the 100HR service kit but it doesn't appear to have the damper guts in it. I've also located a damper service kit for a 1.0 and am assuming that won't work.
    I'm planning to post a write-up on the maintenance which will incorporate a number of online resources. The lack of detailed info about this type of thing online is frustrating with the exception of this thread! The folks on here are extremely knowledgeable and helpful!
    Apr 2018
    For a rebound, the needle with a thread answers. It is held by a small pin.
    There are two reasons: the needle broke, or the pin broke.
    But, rebound works only on low return speed. If the speed is high, then the shimstacks are opened, on the high-speed compression platform. This platform has a Glide Ring. If glide ring is broken, or shimstacks (unlikely), then all the oil will flow through this platform, so the rebound button will not affect anything. At any speed. Even, perhaps, the oil has already become too dirty.
    Particles of rubber (dirt) hit the shimstacks. Another option: A shaft was turned off. Shimstacks are not pressed, all oil flows through the platform.
    The usual cleaning and oil change helps.
    2) Do you need KH125/A, but this set does not have u-cup rings, - the most important seals. You can refer to the headshok service center, they definitely have, for example to eightyaid (88+).
    in any case, I advise you to change the oil and seals every 100-200 hours (2K-5K km) of driving. If you want that the damper lived long... And oil in bushing every 50-100 hours. And seals in air spring system every 100 hours).
    P.S. sorry for my English)
  28. #1028
    Mar 2018
    Update on my post from last week regarding the lefty 2.0 rebound not working correctly. Upon disassembly, I noticed that the solo air bumpers (not sure exactly what they are called) were cracked and pitted. I replaced them with the 2Spring kit and things are functioning exactly as I expected.
    I followed the cannondale 100 hour service video which made the process extremely simple. I did of course need the special tools they require for assembly as well as a number of small pics, scrappers and tweezers.
    While inspecting the damper shafts during re-assembly, I noticed a very small pit in the outer surface of the shaft. Nearly too small to see, it can be felt when the upper air seal runs over it. I fear this will eventually eat the inner upper air seals and potentially the seals inside the damper itself as they repeatedly run over what is likely a very small but sharp edge. I'm not sure if this was like this before dissasembly or potentially something I did during the process. Regardless, I put everything back together and ordered a new damper to be safe. I'll complete another rebuild in a few weeks.
    I can't emphasize the importance of using the cannondale shaft clamps or equivalent enough. These need to be very clean and burr-free and need to be aligned before tightening into a vice. Although I'm not sure I caused the damper shaft damage, I could easily see how it could happen if only a small spec of dirt or metal were to get trapped in between the shaft and the clamps.
    As many have written before, this was not a complicated task. I did change from the PBR to XLR as a part of this maintenance as well. Again, this was not difficult provided you have patience, mechanical aptitude and proper tools. Watch all the videos you can and read this thread. A lot.
  29. #1029
    Quote Originally Posted by alexdi View Post
    Does anyone know if a Reverb remote will work in place of the XLoc?
    I've got the a XLoc Full Sprint controlling my Hybrid 1.0 Lefty and a Monarch XX. I'm considering trading out the Monarch, I'm wondering if I can pull the remote off an old Reverb to maintain the Lefty's lockout functionality.
    EDIT: Nevermind, silly me. I just realized there's no "locked in" position for the Reverb.
    Xloc off an RS-1 should work just fine?
  30. #1030
    Reputation: Josh_W's Avatar
    Aug 2010
    Quote Originally Posted by MendonCycleSmith View Post
    Reducing travel can be done by you, in about 5 minutes.
    Reducing height however, is a more involved process. Easy for someone with the tools, and parts, but not a simple snap, pop type job like travel reduction is....
    What would need to be done for height reduction? I was thinking that with reduced travel I could just slide the lefty up in the clamps to reduce height - no?
    I'm daydreaming about picking up an '09 Optimo cyclocross frame with disc brakes, and doing a Lefty4All conversion to assemble a Made in USLATETM.
    I could start with an Oliver from an actual Slate, but if I could pick up a pre-2011 Lefty for a couple hundred and have it serviced an modified, it would be more satisfying (and likely to happen) than dropping $1200 for an Oliver to attach to a $200 frame.
    FS: Cannondale Rush XL 24lbs, Cannondale F? CAAD5 XL
  31. #1031
    Scalpel Fan
    Quote Originally Posted by Josh_W View Post
    Just put drop bars on the Head Shock equipped SL3000 that is for sale over in the Caffeine thread. I want to buy it myself, but it is too big and my wife would literally scream at me because my current bike status is N+1 where N = the number of bikes I told my wife I would have after buying the latest bike.
  32. #1032
    Aug 2010
    Quote Originally Posted by Quentin View Post
    This one? I actually already have the XL one in the post before that. I've been thinking about putting drop bars on it to go with the aeros, but I want to keep the CAAD5 frame a wheel-swap away from MTB mode, and build a sub-20lb bike for road racing.
  33. #1033
    Scalpel Fan
    Yup, that one. Haha.
    I built the one on the left for my wife. Optimo frame, 650b wheels. I also have 700x28 road wheels for it and the Slate.
  34. #1034
    Apr 2018
    I have a 2005 Cannondale Jekyll, and just replaced the stock Manitou Splice Super fork with a 2012 Lefty PBR Max 140. It's a brand new unit. All I can say is, holy crap! What a great ride! The small bumps just don't exist, and the lockout worked great on climbs. I have arthritis in my hands, so this was a worthwhile investment for me. While far from cheap, I feel that this is the best thing I could have done with this excellent bike!
  35. #1035
    May 2018
    Hi,
    I just designed and tested 3d printed castle tool for lefty 2.0. If someone miss it and have access to 3d printer https://www.thingiverse.com/thing:2891233
  36. #1036
    I like cake.
    Hello everyone, I just picked up an FSI frame to build up into a SS, because everyone needs a SS in their fleet.
    My question is, since I need a lefty 2.0 for the new XL frame, can I get a 120mm lefty 2.0 off a Habit and reduce the travel to 100mm? There are more 120mm lefty 2.0's around, and hence they are cheaper. As long as I find a 55mm offset one of course. I know it is a relatively easy process to reduce travel with the lefty 1.0, but I can't find any information on what parts I would need and how to do it to the lefty 2.0, if it is possible at all. Can anyone chime in with some clarification?
    I like cake
  37. #1037
    May 2018
    Hi,
    have someone list (for lefty 2.0) of orings with dimentions used in air spring (2springs), knob and damper ? Like this one http://forums.mtbr.com/attachments/c...l-etc-dlr2.jpg
  38. #1038
    Any thoughts on the new Lefty Ocho? Curious as to what people who have experience with Lefties think of it, esp someone like MendonCycleSmith.
  39. #1039
    Oct 2015
    Quote Originally Posted by king_dave72 View Post
    There's some chat in the 2019 thread. Someone mentioned the automatic bearing reset feature is gone and that the air spring and damper are parallel as opposed to stacked on top of each other. The new damper looks good, but I think the 2.0 damper was good enough.
    What bothers me the most about it is nothing really to do with it; that the 2.0s are going to be gone in MY19 so the question of how long 2.0 spares will be available needs to be answered. It might be that I end up riding the 2.0s i have to destruction then binning them in favour of Fox or RS.
  40. #1040
    May 2015
    Quote Originally Posted by Howards View Post
    My F-Si is already getting long in the tooth as far as race rigs go, being a 2015. It has some good race miles on it! I figure that when parts are no longer available, I'll just move on to a new bike.
  41. #1041
    Feb 2005
    All part of Cannondales end game (now).
    Change the design entirely, every couple years, and dropping *old* product parts immediately.
    Buyer beware, you're not buying "cutting edge" you're buying profit driven design obsolescence.
    Sad, considering how long the old company kept existing designs supported, and even retrofittable....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
  42. #1042
    Might be something for Mendon; but perhaps others might now this as well.
    The 100mm lefty "titanium" (2000 era) didn't hold air and was leaking oil, so it was way overdue service.
    Got hold of the seals (HD166), and after a long search managed to get a kidney castle tool to open such a lefty.
    There is 1 set of seals/bushing I can't replace; I don't know how to replace the inner and outer seals on that top white plastic nut. How do you get to it?
    I see 2 (11mm I think, not sure) cutouts on the damper shaft, do you dissemble it like that. Or should you be able to remove the black top cap of the shaft and slide it out? Want to check before what is supposed to unthread and what not, before I break it
  43. #1043
    May 2010
    Lower removal
    Hi guys,
    some one knows how to disassembly, needle bearings and the lower leg, i try to pull but nothing happens.
    Attached Thumbnails Attached Thumbnails The official Lefty thread, tech, mechanical, etc-20180612_192445.jpg
  44. #1044
    Oct 2015
    Hybrid or 2.0? Just pull on it really, really hard.
    Hah no I'm kidding.
    There's a clip that keeps things together. You need a highly specialised tool to undo it. And to put it back together again.
    Bin it, strip it for parts or get it fixed by Cannondale.
  45. #1045
    Jun 2018
    Afternoon chaps, not sure if this is the correct place to post but I have just bought a raven lefty and its missing the rebound knob. I cannot for the life of me workout which one it needs, spent hours on google and even bought a replacement (kf229) and it doesn't fit. Made a very expensive paper weight! Any advice or a part numbers thrown my way will be greatly appreciated! Pics attached.
    Attached Thumbnails Attached Thumbnails The official Lefty thread, tech, mechanical, etc-screen-shot-2018-06-15-14.49.16.jpg
    The official Lefty thread, tech, mechanical, etc-screen-shot-2018-06-15-14.49.04.jpg
  46. #1046
    Aug 2017
    What's the right kit for the 100 hours service for a Lefty 2.0 with the 2Spring upgrade ?
    I found just this: https://www.cannondale-parts.de/epag...ts/CK5407U00OS
    It seems to me it has too much components, I think it's for a full rebuild.
  47. #1047
    Feb 2005
    I just picked up a 2017 Scalpal carbon-2 with a lefty and the 2nd spring sticker.
    This lefty is new to me and I wanted to send it in for service to cannondale to go over.
    It would be nice to send it meself to Cannondale instead of the local shop if thats possable?
  48. #1048
    Oct 2015
    You'd need to the tooling to remove it. Basically a driver to drive out the steerer tube. But I'd imagine once out it's possible to box it up and ship it to the mothership, assuming you are in the US.
  49. #1049
    Reputation: Rixington43's Avatar
    Jul 2016
    Just adding this post so UK Lefty 1 owners can hopefully benefit from my experience.
    If you're UK based and struggling to find service centres that will still take care of your Lefty then I can recommend Evans Cycles. I know chain stores are usually a no no for most enthusiastic bike owners but Robin at their national suspension service centre was super helpful and, despite me needing to order a new boot from Germany since Cannondale UK where not proving helpful, did a stellar job breathing fresh life into my still coil sprung Max 140 FFD. If you can drop your fork into one of their branches then they will ship it to their service centre and back to the same store for free. Very well priced service and Robin stayed in touch throughout to answer any queries I had.
  50. #1050
    Oct 2015
    Good tip, cheers!
  51. #1051
    Reputation: ejreyes6's Avatar
    Dec 2010
    Quote Originally Posted by rupps5 View Post
    I have one of thes eremote lockouts new for sale if anyone is interested message me.
  52. #1052
    Aug 2010
    What's the current status of ELO maintenance? Looking at picking up a Carbon SI ELO fork cheap that does the suspension job, but the ELO just whirrrs on stripped out gearing.
    Is Cannondale still ale to retrofit them with manual lock-out if I send it in?
    If I don't care about locking it out, are the rest of the fork maintenance parts available to Mendon and others?
  53. #1053
    Feb 2005
    Canondale will just laugh at you and force feed you a fork that will die within two years, all while promising nirvana and the second coming of the lord of your choice......
    I can service it, but no, if it's not working, chances are pretty darn good the lockout never will again (though every now and then. seals bring it back). It can be a happy squishy fork for a long time to come though.
    No manual conversion parts have existed for many, many years.
    - FrostyStruthers
  54. #1054
    Aug 2010
    So you're saying a Lefty Ocho is the way to go?
  55. #1055
    Feb 2005
    Oh, absolutely.
    - FrostyStruthers
  56. #1056
    Aug 2010
    Elo
    Has anyone had any luck with Henky's 3D-printed ELO manual conversion?
  57. #1057
    Feb 2005
    Had one in the shop awhile back, utterly destroyed the damper. Junk, like so many wondrous, why didn't I think of that sooner, things sold on line, that you never see used in real life.
    Either accept no lockout, scour the webz till you find a donor DLR with every last one of it's unobtanium parts, (and then get lucky it's not been trashed by some DIY effort gone wrong) or buy a fork newer than 2005, and they are far more serviceable in that date range.
    - FrostyStruthers
Members who have read this thread: 199
