Results 1 to 12 of 12
    I'm just messing with you
    Reputation: wv_bob's Avatar
    new life for old paint sample tubing
    My wife snagged these at an LBS that had stopped carrying Cannondale. I heard all they were good for in the shop was falling over making a racket and a mess. The thing turns on the axle so I'm thinking about adding some prop wings for the wind to blow ... anyway ...
    Attached Thumbnails Attached Thumbnails new life for old paint sample tubing-dscn0411.jpg
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    DIY all the way
    Reputation: Mr.Magura's Avatar
    Aug 2010
    She's a keeper !
    To make it rotate, take a look at how anemometers works.
    Magura
    Thanks for that tip, it's just in time because I just tried some cardboard prototype props, and it probably turns less with those than it did without them.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    looks flexy
    Honestly... ahh I give up
    Tried adding saddles and puttng it on a fixed base but it wouldn't spin. Either the saddles don't catch enough air or the tubing weighs too much.
    Thanks for the use of your forum space!
    Attached Thumbnails Attached Thumbnails new life for old paint sample tubing-dscn0417.jpg
    DIY all the way
    Aug 2010
    You have the angle of the saddles wrong, that's why it won't work.
    The saddles must be turned, so that they are pointing towards the center.
    Like they are now, you'll need a hurricane to make them work.
    Magura
    Feb 2005
    Tie fishing line to the anchor at the top end of the tubes where the chain is. Drop it down through, and tie a flat object of some kind (I'm thinking rear wheel dork discs would be PERFECT) to the end that comes out at the bottom. A few nuts tied along the length of it to whack the insides, and you have a whole mess of noise making potential.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Quote Originally Posted by Mr.Magura View Post
    Magura
    If I understand that you mean the nose of the saddle should be pointed directly at the hub so the saddle is at 90* to the center of the hub?
    If so, I started with the rods welded at 90* and tried that. No joy that way either.
    Attachment is the image I based it on - I welded the arms in the opposite direction from that, but I think that just means it will turn opposite of the DIY anemometer shown.
    This is the main page for the anemometer project:
    Hacker's Bench : Inexpensive DIY Anemometer
    Attached Thumbnails Attached Thumbnails new life for old paint sample tubing-pvc29.jpg
    Quote Originally Posted by MendonCycleSmith View Post
    Good idea about putting the dingers inside, I really didn't want something hanging from the center of the wheel, banging up the outside painted part of the tubes.
    DIY all the way
    Aug 2010
    The way you started out was right.
    If you take a closer look at the DIY anemometer, it closely resembles that, as the hub the spoons are attached to, is rather small.
    I'd guess your next step is to service your hub, as it is not running smooth enough then, or you need bigger saddles
    Magura
    That thing would look great in front of my trailer!
    Quote Originally Posted by smilinsteve View Post
    Only if you've got a couple of junk cars there to set it off
  1. Sample proposals
    By wildskycomet in forum Trail Building and Advocacy
    Last Post: 08-17-2011, 08:12 PM
  2. Sample signage...
    By formica in forum Trail Building and Advocacy
    Last Post: 01-14-2010, 09:25 AM
  3. whats the expected life of frame paint ???
    By hu-man in forum Singlespeed
    Last Post: 09-11-2008, 10:45 PM
  4. positive B sample
    By fat_weasel in forum Passion
    Last Post: 08-10-2006, 03:15 PM
  5. How to Sample Saddles???
    By peterkg in forum General Discussion
    Last Post: 03-12-2005, 04:03 PM
