Results 1 to 12 of 12
    New Lefty doesn't hold air
    Good morning everyone. I just bought a leftover 2013 F29 Lefty and the fork doesn't hold air. It leaks about 20 pounds of pressure after every ride. I thought I read somewhere, on the Lefty section, that I should turn the bike upside down and let it sit a while.
    Can anyone elaborate on this please?
    Thanks,
    Tom
    Feb 2005
    That's old advice. Current gen forks like yours won't benefit from that.
    Check that your valve core is tight, I'd also pull the air plug (after letting the pressure out of course) and see that the seal on it is in tact, they do sometimes catch and tear upon installation.
    Beyond that, you're best to take it to where you bought it, and have them pull the damper and swap seals, they also, can catch and tear occasionally, on installation.
    Easy initial check? Air it up to say, 200, and wipe some soapy water around the bottom where the air goes. Bubbles? You found your leak point. No bubbles? Back to the shop for the above....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Yup,
    Couple of years ago had the same issue with a new DLR and it was the easily fixable " valve core " .
    Wrenches can be found at Walmart or any hardware store.
    bubbles from the Schrader valve and from the nut surrounding it. Should I just remove the nut, slab some thick grease on the threads and retighten it? Here's a video of the bubbles I took.
    Leaking fork - YouTube
    Feb 2005
    Two things first. Snug the core with a core tool, and snug the plug with a socket.
    Still bubbling from both? Release pressure, replace core, unscrew plug, replace seal, repeat test.
    A bit of grease will help snug smoothly, but is in no way a leak preventer.....
    - FrostyStruthers
    Thanks. I'll definitely check it. Any idea what size socket I need? I don't have one large enough at home.
    Feb 2005
    24mm, and be careful, those wrench flats are fragile, and thin. Good downward pressure during the initial "cracking" will save a lot of head banging on wall.....
    - FrostyStruthers
    Oct 2013
    Great post. Mine leaked from day 1 so I sent it back. Great CS from Cdale. I'll try the above if it happens again.
    Sent from my S2 using Tapatalk and CM 10.2
    Thanks. Took the cap off, cleaned and re-greased it and problem solved.
    I have another idiotic question if you don't mind. My F29 has a 27.2 seat post. What is the outer diameter of my seat tube? 28.6 or 31.8? Thanks again.
    Feb 2005
    Cannondales were 31.8 for years, some road frames in recent years have bumped up to 34.9 though, despite remaining at 27.2 post diameter. Additional swaging for BB stiffness would be my assumption.
    My guess would be 31.8, but I don't sell the bike brand, so measuring is the best way. No way is it 28.6 though....
    If you're buying a new FD, just buy a 34.9 as they all come with shims nowadays anyway.
    - FrostyStruthers
    Reputation: need4gforce's Avatar
    I have a pul I'll sell you on the cheap. I don't use it anymore since I went 1x11. Message me if interested need4gforce@gmail.com
    Happy trails~
    Larry Miller-
    www.laxon3.tumblr.com
  1. The bike doesn't matter
    By Innota in forum Passion
    Last Post: 09-08-2013, 08:17 AM
  2. There's always gotta be one, doesn't there?
    By skiahh in forum Colorado - Front Range
    Last Post: 08-20-2013, 07:59 AM
  3. A Fox CSU that DOESN'T click/pop/creak?
    By Pau11y in forum Shocks and Suspension
    Last Post: 07-02-2013, 11:25 AM
  4. bb7 mount doesn't fit fork
    By nashwillis in forum Brake Time
    Last Post: 06-22-2013, 06:20 AM
  5. Lefty Max won't hold air psi ?
    By grchmason in forum Cannondale
    Last Post: 07-26-2011, 02:55 PM
