Results 1 to 3 of 3
    old biker
    new jekyll dyad pressure set up
    hi all ,
    i just buy a new cannondale jekyll 2011 himod1
    great bike , but i'm not satisfied of the dyad pressure set up suggest .
    the bike is too firm even if in flow mode
    so , i try to change the pressure and now i ride well with +290 / -210 psi
    i'm weight 78 kg
    somebody jekyll owner can advise me going by his experience ?
    May 2010
    I weigh about the same as you 170lbs. I started my DYAD pressures based on the label recommendations (+320/-270) but I too found that way to rigid. I've slowly dropped the pressures down until I found it to my liking and now I'm at (+264/-222) so now I'm three notches below what Fox recommends. FYI, I ride very gnarly trails...
    So it doesn't suprise me you are finding the Fox recommended settings high.
    BTW, Fox recommends 40% sag...when I measure sag on my DYAD at the current settings it is close to 40%.
    HTH.
    old biker
    thank you dkestar for accurate reply ,
    I proceed too reducing pressure like label recomandation ,
    but it doesn't satisfying me .
    so I try to change pos. and neg. air pressure INDEPENDENTLY by the label .
    I notice that , on equal pos. pressure , reducing neg. pressure you have a faster rebound and a sag reduction.
  1. 2011 Jekyll DYAD RT2 Build Error
    By dkestar in forum Cannondale
    Last Post: 07-28-2011, 04:42 PM
  2. Dyad Shock on Jekyll
    By smilycook in forum Cannondale
    Last Post: 05-13-2011, 11:37 AM
  3. Replies: 3
    Last Post: 05-06-2006, 08:05 PM
  4. repost - jekyll with swinger air pressure
    By coolatt in forum Cannondale
    Last Post: 06-20-2004, 03:11 PM
  5. jekyll with swinger air pressure???
    Last Post: 05-18-2004, 06:15 PM
