have been using(with great success) an older lefty carbon SL 90mm. it has been on many of my race bikes.
looking to build a newer carbon F29(with a triple hollowgram crank) and use a carbon lefty with a remote lockout button on the handlebar.
my thoughts are 100-110mm suspension. 200mm disk brake compatible. light weight. just not sure as to which model i should target?
i will run the fork mostly locked out and then switched on when trail gets really really rough. i tend to run fork soft and fast at that point. no need to worry about big jumps or landings.
i weigh 155lbs and race XC to endurance but don't hold back on rocky descents. I ride a ridge single speed 85% of the time training hence only using the fork suspension sparingly.
thx in advance for your info/thoughts
