Results 1 to 13 of 13
    Need help replacing Jekyll's handlebar with Sunline handlebar
    I have a 2000 Jekyll 500 with the stock stem and handlebar and I just bought Sunline's flat bar, stupid me didn't know/think that the diameter of the stock stem that holds the stock handlebar is why smaller then the diameter of new Sunline.
    Any ideas on the fix, return the Sunline, maybe there is a replacment on the stock stem that can handle a wider handlebar?
    Thanks.
    Reputation: Duncan1104's Avatar
    Quote Originally Posted by jerry98vert View Post
    Thanks.
    You should get a new stem. Does the bike have a lefty? If so I have lefty stems piling up.
    rebelssof@yahoo.com
    Guest
    Yep get a new stem.
    Thanks but no Lefty, it's a head shock and where to find a 1/2" stem and also the stem has an angle and would like to keep the angle how do you tell what the angle is?
    Well I did some research and I need a 1.5 steer dia. with a 25 degree and 31.8mm clamp size, like I am going to find that.
    Headshok and Lefties use the same size stem. They are not actually 1.5" they are slightly bigger. So you will need a dedicated Cannondale Lefty/Headshok stem with a 31.8 bar clamp. Do you know what length?
    Quote Originally Posted by Duncan1104 View Post
    I don't know how to tell it is prett long I would say the longest Cannondale makes.
    Pretty close to what you're looking for.
    Cannondale MTB HeadShok Stem 20D 120mm 31.8 Black | eBay
    [QUOTE=pcmark;8446976]Pretty close to what you're looking for.
    [Thanks blocked at work will look soon.
    Quote Originally Posted by pcmark View Post
    Thanks I just saw it is $75 a good price?
    You may be able to find it lower if you search around. Headshok stems for a 31.8 bar are fairly uncommon.
    No, $75 for that is way over priced. I'd keep a look out for something cheaper.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    It would be cheaper to return the 31.8 bar and get a 25.4 bar to fit your existing stem.
    Less isn't MOAR
  1. Flat handlebar vs riser handlebar
    By RidgeRunner in forum General Discussion
    Last Post: 05-16-2014, 07:49 AM
  2. Sunline V-Two handlebar
    By I.V.A. in forum Weight Weenies
    Last Post: 09-20-2008, 01:23 PM
  3. Carbon handlebar... broken... think about replacing yours
    By Count Zero in forum General Discussion
    Last Post: 03-02-2008, 12:30 PM
  4. Replacing SJ Handlebar - Which of these?
    By arctic303 in forum Specialized
    Last Post: 10-14-2007, 10:24 AM
  5. Specialized Carbon handlebar vs. Easton Carbon handlebar
    By LeStrong in forum Weight Weenies
    Last Post: 08-10-2006, 05:22 AM
