    BLAH BLAH
    Need Help Removing LEFTY PBR 100 29 off an 2013 Scalpel 29er 3
    It has a non OPI steerer and stem so traditonal still but the clamps are part of the fork so the rotating out of the way method I use to use wont work. I can get the steerer loose of the top clamp and bearing but am having trouble getting it out from the bottom bearing so the Fork is half stuck on the bike.
    Any Tips?
    Whats this line for?
    BLAH BLAH
    Im thinking I just need to beat it out...
    Jul 2013
    Jep beat out. If its realy stuck try puting somting cold and frozen in it so it wil shrink a tiny bit. Workt fine fo me. Good luck
    LA CH»VRE
    Reputation: Dan Gerous's Avatar
    Normal, it's a tight fit. There's a Maglite flash light that fits right in, you can use it to push the steerer out (hit it with rubber mallet).
    And obviously, the Lefty's clamp bolts must be loosened and the front wheel has to be off.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
  1. My new 2013 Scalpel Carbon 29er!
    By fueledbymetal in forum Cannondale
    Last Post: 04-01-2013, 03:13 PM
  2. 2013 29er Scalpel 1 or Scalpel 2
    By RyderX in forum Cannondale
    Last Post: 12-16-2012, 11:26 PM
  3. 2013 '120mm' Lefty on a scalpel 29er?
    By Quinner in forum Cannondale
    Last Post: 06-22-2012, 12:29 PM
  4. Replies: 2
    Last Post: 04-28-2012, 07:42 PM
  5. HELP NEEDED Removing Lefty from Flash 29er
    By edj in forum Cannondale
    Last Post: 10-26-2011, 06:24 PM
