    Reputation: Denis's Avatar
    Need help: Mounting a carbo lefty...
    I just received my 1FG frame and Carbon Lefty ELO.
    Unlike my old regular ELO, the carbon lefty triple clamps (btw, why are these called triple clamps?), are "glued" to the carbon leg, so there is no way to adjust the distance between the two clamp. On the regular lefties, the top clamp is actually removeable.
    So... now it seems that the distance between the two headset bearings on the 1FG frame is shorter than the distance between the two clamps on the Carbon lefty... (the silver lining is that it could have been the other way, then I'd be really toast...). Anyone has had some previous experience with that?
    It looks like I am going to need a couple of spacer, any suggestion on where to find some?
    DC
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    I tought Cannondale bikes all had the same headtube length...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    photos?
    Having a hard time following you. Can you provide photos?
    gfy
    Quote Originally Posted by Denis
    DC
    I had a similar problem with a 2002 (grey clamps) carbon elo a few months back, the 2 clamps were 5mm wider apart than any other carbon lefty i had ever seen. I ended up stacking a few of the Si bearing dust caps to eliminate the space between the bearings & clamp. How bizzare I thought only i had those abnormal issues?
  1. Lefty sans compression adjuster?
    By SpinWheelz in forum Cannondale
    Last Post: 10-13-2004, 10:34 PM
  2. Lefty Front Hub Options?
    By morrisond in forum Cannondale
    Last Post: 09-16-2004, 07:59 PM
  3. cannondale lefty
    By patpend2000 in forum 29er Bikes
    Last Post: 07-06-2004, 02:00 PM
  4. Cannondale Lefty Max+ compared to TALAS :my $.02
    By dawgcatching in forum Shocks and Suspension
    Last Post: 04-13-2004, 10:39 PM
  5. Lefty Max vs. Lefty ELO (upgrade on my Raven)
    By Denis in forum Cannondale
    Last Post: 04-10-2004, 10:27 PM
