Results 1 to 3 of 3
Thread: Need a head set
    Need a head set
    Got a C'dale frame off ebay got a HeadShok off ebay.Need a headset to put it all together my local dealer is a jerk ( he is also rude and arrogant).Does any body know where I can get one?
    TimT
    The "headset" on a Dale is basically 2 bearings. The cups should built into the frame or removable (depends on model). The cups are rarely missing.
    This is the bearing:
    This is where to get it.
    If you are also missing the cups, you are stuck going to a LBS. Don't you have more than one LBS in your area?
    Only guy in town
    There are other LBS's in town but the local dealer for C'dale has an exclusive on C'dales. I was told by a former mechanic of his that I'm missing the piece that screws on the bottom of the fork that sets the bottom bearing and a couple of pieces on the top that set the top bearing.
    TimT
  1. Is this thing On?
    By Pete in forum Ellsworth
    Last Post: 05-02-2009, 10:27 AM
  2. My Matt Chester
    By shiggy in forum Custom Builders & Other Manufacturers
    Last Post: 02-18-2004, 01:35 PM
